Old 09-21-2016, 04:27 PM   #1
forestb
forestb's Avatar
Battery Disconnect Switches
I am trying to figure out if I want to install a battery disconnect switch so that I can Disconnect my battery and lock my hood for extra security.
Does anyone have any recommendations?
Has anyone used a Battery Dr. Automatic Battery Disconnect Switch? It allows you to disconnect your battery using a key fob.
forestb is offline   Reply With Quote
Old 09-21-2016, 08:55 PM   #2
racecougar
racecougar's Avatar
Re: Battery Disconnect Switches
I use a Taylor #1033 in my race car. It's a durable, quality piece.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-21-2016, 09:03 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Ditto, Taylor is quality stuff. Just be sure and look at the 'CONTINUOUS DUTY" rating of what you get. The Summit house brand switch is rated at 20 amps ,, the Taylor is rated at 180. There is a HUGE difference in the cheap ones continuous vs momentaty peak
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-21-2016, 11:29 PM   #4
AcampoDave
AcampoDave's Avatar
An old hotrodder at a drive in cruise nite told me to disconnect the gound side. He told me it's safer because current isnt a factor...I disconnect my ground terminal at the battery before I lock my hood. I used to undo the hot terminal but it seemed like the battery post would get oxidation on it and I was always having to clean it with a wire brush.
AcampoDave is offline   Reply With Quote
Old 09-22-2016, 10:53 AM   #5
forestb
forestb's Avatar
If I am using it for a weekend cruiser which kind would you recommend.
Old 09-22-2016, 12:29 PM   #6
zach_carver
zach_carver's Avatar
Ive also wanted to do this. Especially as many trucks Ive seen lately stolen.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 09-22-2016, 02:15 PM   #7
racecougar
racecougar's Avatar
If you only need to interrupt the main circuit, then I'd recommend the Taylor #1032. It's $34 on Amazon (with free shipping if you're a Prime member), $35 at Summit, $37 at Jegs....
That said, if it were me, I'd spend the extra $3 or $4 and get the Taylor #1033, just in case I needed the ability to interrupt another circuit separately in the future.
