latch problem w/ Billet grille
When I installed a billet grille, I found out that getting to the hood latch is nearly impossible. I have seen trucks with a cable pull style hood latch that pops open from in the cab. What year of truck could I get one off from that I can adapt to fit the 69-72 style hood? Pictures would be great. Thanks
CB
Craig Berland |
I have that problem too. Too make matters worse I cut about 2 inches off of the front of the lever. I just keep a wrench in the glove box and use it through the grill opening. It's easy and you know people won't be opening your hood.
If you get a cable latch to work you can also cut off a lot of the lever so no one will be opening your hood.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
there was a post on how to do it. i think they used tv cable from the the cab and when u puled it it it pulled the latch back. i think
70 longbed 496/th400/Ford 9" |
my friend welded an extension to his handle that hung behind the bumper works great but then you have to lean over and show the world your butt when you pop your hood.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
go cyclones
here is the thread http://67-72chevytrucks.com/vboard/s...threadid=61406
