Old 09-21-2016, 09:17 PM   #1
jr1000yarder
Bucket Seat Question
I have the opportunity to buy a set of 72 Blazer buckets...my question is will 69-70 foam fit these frames...are they the same frame is my question I guess. I know I will need passenger brackets to be correct for my truck just want to make sure the frames will accept the 69-70 seat foams before I commit to them.
Thanks, Rich
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 09-21-2016, 09:51 PM   #2
davepl
davepl's Avatar
Re: Bucket Seat Question
To my knowledge the only difference is the Blazer bucket gets a back, but that might be the Suburban I'm thinking of (or both). But as far as I know, the rest of the seat frame is the same.
We have a few upholstery experts who should be along shortly though, I'm a little hazy on this one.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-22-2016, 12:15 AM   #3
FirstOwner69
FirstOwner69's Avatar
My understanding is that the foam for 69/70 buckets is different from the 71/72 foam. It may be only the foam for the backs that differs. I have no idea if the 69/70 and 71/72 frames themselves are different. As Dave said above, the Blazer and truck buckets are the same except for the back on the Blazer buckets and the passenger side mounting brackets.
Here's a link to a previous thread that may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=437963
FirstOwner69 is offline   Reply With Quote
Old 09-22-2016, 08:06 AM   #4
custom10nut
custom10nut's Avatar
I think the foams are the same size, but the frames will not fit in the cab of your pick up. The mounts are longer.
I used Blazer buckets in my truck but had to use slider sets from two bench seats, and fab brackets for them to fit
custom10nut is offline   Reply With Quote
Old 09-22-2016, 08:14 AM   #5
71swb4x4
71swb4x4's Avatar
The driver's side is exactly the same as a pickup bucket as far as the frame and brackets is concerned. Passenger side only difference is the flip forward bracket.
If you have a bench seat from the factory it is a little work to put factory buckets in, the holes are not there already. There are plenty of threads on how to get the job done.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-22-2016, 12:49 PM   #6
jr1000yarder
Thanks. I'm aware the passenger bracket is different and I'll need to fetch one. My question was the frames.........
Thanks Firstowner69, that was my understanding also.....just need to know if the frames are interchangeable.....
IT IS WHAT IT IS
Old 09-22-2016, 02:24 PM   #7
FirstOwner69
Here's at least one thread that says they are the same. See SS Tim's post #3.
http://67-72chevytrucks.com/vboard/s...et+seat+frames
Old 09-22-2016, 02:32 PM   #8
jr1000yarder
GOT it. Thanks!
IT IS WHAT IT IS
