Heater core: New or redo old one?
I'm curious to hear any experience you guys have between buying a new heater core vs having an old one cleaned up at a radiator shop. Mine is leaking, and I have a spare also, but assume it leaks as well. What's the prevailing wisdom here?
Posted via Mobile Device |
Re: Heater core: New or redo old one?
New ones are pretty cheap I'd just replace it.
Get the original one fixed. My experience with the new ones is that they don't fit very well. And the quality is pretty bad. But thats just my .02
1970 SWB Build |
Get the old one fixed if you can. It was made during a time when makers made things of thicker metals. The copper back then was "virgin" too, meaning it hadn't been once something else and then melted down and reused.
I tried to get my heater core repaired but the leak was too severe. The radiator shop found me a copper replacement that fit pretty well. I kept my original and maybe I can have it recored when I have the funds. I even plan to get my original radiator recored when I have the funds...I want to keep my truck as original as I can. Assuming that you must replace yours, I suspect you can find a copper/brass one as I did. I think Classic Industries carries those in their catalog. I have read on this forum that the aluminum replacement heater cores may or may not fit. |
If you can, get the original done - the repros are thinner. Problem is a few people who have brought this up in the past have said that they were unable to get them recored.
I guess they could still boil it out and resolder it, though. You'd hope anyway!
Recore the old one. It is 2 1/2 " and new ones are 2" and have to be shimmed to fit correctly
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
I tried to get my original's leak fixed and the company did try, but it kept failing the pressure tests.
as much trouble as they are to remove I would put a new one in. I would not trust a 40 something year old repaired one. I just put a new one in a truck and it fits just fine.
#9 | |
Where did you get this one that fits? I've been reading that most new ones are smaller...
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Moderator
![]() Join Date: May 2007
Replace it. I did years ago and never looked back. I don't recall if it needed shimming, if it did it's no big deal.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
If the leak can be repaired, do it!
I was at a radiator shop last month and was talking to the owner who has been in business for 30+ years about the four heater cores I have that need new 2 1/2 inch cores. He said he can defiantly repair them if he could just get the cores. He said that the problem is that all the suppliers have stopped making the bigger cores. Everyone just wants to deal in cheaper mass produced junk. It's sad to see that radiator shops are becoming a dying breed.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
![]() ![]() Join Date: Feb 2009
Unless a restoration is possible, I think I'll just reinstall my old one. About 45K on it, though 25 years. On the plus side the system is very clean. Since I can remember I've always used distilled water, less one recent flush.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#13 |
Ever replaced one in the truck? They're no fun, put in whatever you think has the best odds of living the longest time!
#14 |
#15 |
My Repro fit well and does not seem too much lighter then the orig. IDK how it works yet, I am a call center employee so cannot handle taking off that steel hood the size of texas myself to put the assembly back on (drove it without the assembly for a few months through the summer, just bypassed the lines)! lol
But one thing is for sure I am going to be putting it to the test, Northern Sask and it is my daily driver lol |
