71-72 vs 73-8x? A-Arm questions
Gents
Are the '73 & up A Arms dimensionally the same as 71-72 A-Arms? Meaning, will cross shafts & ball joints for 71-72 models fit in both upper & lower 73 up A-Arms? Thanks! |
Re: 71-72 vs 73-8x? A-Arm questions
6x-72 C10's use a different type of bushing vs 73-87's so the shafts are different.
If I bought a complete 73+ Upper control arms , would they bolt up to my 71 ?
Thanks |
They will physically bolt-in place.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
The 73 and up are easily rebuildable if needed, parts are cheaper that the 63-72( ie ball joints etc) and more readily available too. You will need to open up the u-bolt holes a bit to accommodate the larger u-bolts from 73 and up.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
