Old 09-22-2016, 03:35 PM   #1
cgster
Transmission Cooler Question
I stripped out my aluminum radiator transmission line threadin and the guy at the radiator shop told me he couldn't fix it so he recommended I get a Hayden 404 transmission cooler and run it behind the radiator. My question is, my trans line is a 5/16 with a 1/2-20 connection from what I can gather. Looking at the Hayden 404, would this work for me as far as line size and connections? Doesn't seem like it would but I figured the radiator guy would know what he is talking about.
http://www.oreillyauto.com/site/c/de...0940&ppt=C0377
cgster is offline   Reply With Quote
Old 09-22-2016, 04:10 PM   #2
davepl
davepl's Avatar
Re: Transmission Cooler Question
I believe he's assuming you will use rubber transmission line to make the connection. It looks like the cooler has barbed hose fittings, not threaded.
On my truck I used all hard line with flare -> pipe fittings to connect the cooler. If you're interested I can dig up the model number, etc, of the cooler.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-22-2016, 04:14 PM   #3
cgster
Wouldn't that transmission cooler have to accept a 5/16" hose instead of the 3/8 inlet that it shows?
Yes, please send the model number of yours if you dont mind. Thanks.
Old 09-22-2016, 04:21 PM   #4
Low69CST
I bought one with npt connections and get fittings to the size and type you want. I used 6AN hose on mine.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 09-22-2016, 04:42 PM   #5
WarMonger
WarMonger's Avatar
x2 I mounted mine in front of the radiator and used the AN fittings.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 09-22-2016, 04:44 PM   #6
WarMonger
WarMonger's Avatar
If the radiator is out of the vehicle, go get a pipe thread to pipe thread or AN fitting and get someone to weld it in the hole of the radiator.
1970 C20
-_--_--_- ______
1972 K5
Old 09-22-2016, 04:50 PM   #7
cgster
Did you have to build your own brackets to mount it?
Old 09-22-2016, 05:55 PM   #8
WarMonger
WarMonger's Avatar
I will take some pics tonight. I used Adel clamps and they fit around the bends of the cooler and mounted them to the core support. then I got AN style bulkheadfittings and piped it through the core support. Hard lined the entire way. no hoses.
1970 C20
-_--_--_- ______
1972 K5
Old 09-22-2016, 07:44 PM   #9
davepl
davepl's Avatar
Here's a pic of mine - wasn't intended to be a pic of the trans cooler, but it's visible, so figured I'd share it.
Old 09-22-2016, 09:03 PM   #10
Low69CST
I will get a picture of mine. I would mount it in front of the radiator. Behind the radiator the shroud would hit it.
Old 09-22-2016, 09:16 PM   #11
Bigdav160
Bigdav160's Avatar
If I was needing a cooler (to run without the factory in radiator cooler) It would be a plate cooler like on Dave's picture not the Hayden posted.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-23-2016, 12:09 PM   #12
davepl
davepl's Avatar
FWIW, I run both in series.
Old 09-25-2016, 09:29 PM   #13
Low69CST
A picture of my cooler.
