Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 09-22-2016, 08:47 PM   #1
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
46 gas pedal help
We are building a 1946 chevy pick up and have a gas pedal question .....What are we missing....What connects the ball to the pedal ?....we have the link pin but can't find a picture of the missing part .....any help ?
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 09-22-2016, 09:08 PM   #2
Hewfil1
Hewfil1's Avatar
Re: 46 gas pedal help
You have the wrong end it would seem. Should be flat and have a bolt hole to go in. Should be one solid arm, not anything connected to a ball. (See attached pic)
Hewfil1 is offline   Reply With Quote
Old 09-22-2016, 09:14 PM   #3
wutnxt
A couple of pictures showing the dual carbs it also has a set of fentons....led projection head lights .....dropped straight axle....4 wheel power disc brakes
thanks
Old 09-22-2016, 09:16 PM   #4
wutnxt
Wow....thats nothing like we had what we had when it came in.....Thanks for that
Old 09-22-2016, 09:21 PM   #5
Hewfil1
Hewfil1's Avatar
No problem. Found the info on a site where a guy was trying to solve cab noise while driving. Loose pin on his turned out to be the problem so, luckily there was a picture showing it.
Old 09-22-2016, 09:42 PM   #6
wutnxt
Well we are having a problem with the springs on the carbs and stiff linkage bending the rod we made so was wondering what it had from the factory......But i searched all over and couldn't come with a picture or anything other then the pin and the pedal. Thanks again I knew someone here of the forum could help me out
