09-24-2016, 01:12 PM | #1 |
diagnose screech
I have a screech when i rev engine it happens in neutral and in gear only in second my first gear is granny. it is not a belt squeal. clutch fan seems a little tight but its doesnt sound like an airplane. also throttle response seems to lag a bit it only does it when rpm is low and i give it the gas hard.I wouldnt worry but i hope to motor across country and i know a sticky clutch fan robs power lowers mpg
09-24-2016, 01:27 PM | #2 |
Re: diagnose screech
It's your fan belt!
09-24-2016, 01:40 PM | #3 |
...or power steering. But it sure sounds like a belt. Why do you say "It is not a belt squeal"?
09-24-2016, 01:59 PM | #4 |
20' Daredevil (Ret)
x2 -- why do you say "It is not a belt squeal"?
I'm very curious what the problem is because my K20 has recently developed a similar noise, usually around 1400 rpm. Doesn't always happen and I've been unable to duplicate it in my driveway. I tried soap on the belts -- adjusted the belts -- finally changed the belts. Still have the noise. I hope it's not the water pump, but I hope I find/fix it before changing coolant. A thought on that fan clutch, if you think it's going bad. Inspect it closely for any hint of fluid leakage. Pay particular attention to the back of the unit, where the shaft joins the clutch. That seal might be leaking, and it's kinda hard to see, which makes it easy to miss. Doesn't take a lot of leakage to begin drying out inside.
09-24-2016, 02:00 PM | #5 |
Try some belt dressing Stocker.
https://www.walmart.com/ip/Prestone-...ssing/16817510 |
09-24-2016, 02:04 PM | #6 |
thankyou both for quick reply it sounds different more like metal to metal bearing screech and fan seems a little tight i have adjusted belt and no change im thinking bearing maybe alt. but i kind of think its fan clutch just wanted expert opinion ill change out belt to help diagnose n keep it for spare if you advise
09-24-2016, 02:08 PM | #7 |
Well if its not the belt, then that'd leave you with water pump bearing or power steering pump, I think.
09-24-2016, 02:09 PM | #8 |
only have one belt i installed good wrench engine with new water pump kept alt. and clutch fan and it did it before engine install thanks again you guys are amazing all of you
09-24-2016, 02:21 PM | #9 |
Likely you have the wrong belt.
How deep does your belt sit in the pulley grooves? |
09-24-2016, 02:22 PM | #10 | |
09-24-2016, 02:34 PM | #11 |
09-24-2016, 02:35 PM | #12 |
09-24-2016, 02:41 PM | #13 |
how freely should fan spin when engine is off and cold its kind of tight it does not free wheel. the shaft does look a little oil on it very minor
09-24-2016, 02:52 PM | #14 |
20' Daredevil (Ret)
Hard to describe but I think of it as gooey like it's mired in molasses. It should not spin freely, and should stop as soon as you release it. No freewheeling. Yours sounds normal to me.
09-24-2016, 02:56 PM | #15 |
current belt sits flush hope i describe this correctly the belt does not stick out above pulleys and the contour matches pulley it had wrong belt when i got it and i had the guy at auto parts store come out and look belt is two years old has mmm 10k miles on it I will buy belt and change and keep old one as i have spare carb. distrbutor hoses gaskets carb rebuildkit etc nothing wrong with extra fan belt
09-24-2016, 03:00 PM | #16 | |
20' Daredevil (Ret)
Anyway I have already changed the belts which suggests there's no belt problem.
09-24-2016, 03:01 PM | #17 | |
20' Daredevil (Ret)
09-24-2016, 03:11 PM | #18 |
yes pulleys line up
09-24-2016, 03:16 PM | #19 |
im sooruy meed break hsnds twitching too much now yhankyou im still teading rrdpondrd responsrd dam phine
09-24-2016, 03:30 PM | #20 |
One last thing to check.
Unplug the voltage regulator and test again. If no squeek then it's your altenator charging strongly that puts an extra load on the belt making it slip. |
09-24-2016, 03:32 PM | #21 |
sometimrs i run out of patience i do know how to spell.Anything wring with removinh fan clutvh and starting engine . I only have to ruun it for a moment just thooughht of that
09-24-2016, 03:45 PM | #22 |
You can run it without the fan for a a minute, sure (or less). But make sure the pulley is still bolted on. Don't just remove the fan and bolts! Anything's possible, but it seems like low odds it'd be the clutch making noise.
09-24-2016, 03:51 PM | #23 |
20' Daredevil (Ret)
Yeah, but it *could* be the water pump.... so removing the belt that turns the pump (which also turns the fan), then do a short test run, would help prove or disprove it.
09-24-2016, 04:20 PM | #24 |
09-24-2016, 04:39 PM | #25 |
if i remove belt and sound goes away then it could be belt alt water pump orfan clutch if its still there then its something rlse sound was there beforr new engine and nrw water pump i kept old alt and fan clutch
