c10 Part out
Parting out a 69 c10 short stepper all part prices do Not include shipping
69 E-Brake Assembly ...$50.00 + ride home 68 E-Brake Handle...$15.00 + ride home Door Latches with rods and relay ..$80.00 for the Pair + ride home Door Window Regulators $40.00 for the Pair ..+ ride home vent window assembly window... pair 60.00..+ ride home vent window assembly Single unit fair condition $20.00..+ ride home |
![]() Join Date: Apr 2001
Re: c10 Part out
Jrainman,
Not on your list but since your parting out would you have the bolt and nut that goes on the circular band that clamps the steering column to the bracket on the firewall? I misplaced mine. Thanks, Trukman1
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
Re: c10 Part out
this is what I bagged and tagged as steering column I assume the ring in the picture with the bolt and nut in it.
Re: c10 Part out
Jrainman, That's the bolt I need. I have the ring just need the bolt. How much to 45431? Thanks, Trukman1
Re: c10 Part out
Do you have an upper alt bracket for a v8?
Re: c10 Part out
Re: c10 Part out
driver side
Re: c10 Part out
I will take the steering column mounting parts. Paypal?
![]() Join Date: May 2014
Re: c10 Part out
How are the doors? I'm in northeast PA as well.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Re: c10 Part out
well I am on the fence about the doors they have your typical NE pa bottom rust sydrone but they have some nice straight skins on them I think they are restorable with lower panel patches. if you put the time in to them.
I have not even taken the inner door panels off or removed glass either so I am just going by what i see and fee from the outside. I can shoot you some pictures if you want . |
#11 | |
Re: c10 Part out
Re: c10 Part out
Jrainman, you don't happen to have 6 cylinder motor mount? where in nepa do ya live? I'm in milford.......
#13 |
Re: c10 Part out
Ever get pictures of the doors? I know it was mostly a bad rainy day around here...
#14 |
Re: c10 Part out
im local and would like to know if you have a bench seat and tree shifter thanks
#15 |
![]() Join Date: Sep 2015
Re: c10 Part out
What kind of shape is the grill in?
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
#16 |
Re: c10 Part out
#17 |
Re: c10 Part out
i am looking for a ear axle with 3.73 gears. you wouldn't by chance have one from that truck would you?
#18 |
Re: c10 Part out
Would you happen to have the in bed spare tire carrier? If so how much sipped to 60034?
#19 |
![]() Join Date: Mar 2011
Re: c10 Part out
you guys realize this post is from September 2016 ?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
