Old 09-25-2016, 03:17 PM   #1
mrlobster
Gen 3 camaro rear sway bar frame spacer
I've read many threads about installing a Gen 3 camaro rear swaybar on my '72. I understand that a spacer is needed between frame and end link bracket. Is there a consensus as too how thick that spacer should be? I've read 1", 1 1/8", no spacer...
It will be a 7/8 bar, mounted above the axle, facing rearward, if that helps.
Thanks!
mrlobster is offline   Reply With Quote
Old 09-25-2016, 08:49 PM   #2
Low69CST
Re: Gen 3 camaro rear sway bar frame spacer
I put one on my truck. I can measure it tomorrow. But you can center the bar on the rear end, with the end links assembled, and measure the gaps. That's what I did and ordered aluminum blocks that thick.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 09-25-2016, 08:55 PM   #3
mrlobster
I appreciate that. I was hoping to get ahead of the game with the parts so I don't have the truck down for long mocking it up.
