09-25-2016, 04:57 PM | #1 |
69 chevy with 250 ?
Just got the truck runs ok at high speed but at low speed really have to keep foot on gas to keep it going , any ideas on how to fix this ?
Plugs are new points new cap new help please |
09-25-2016, 05:04 PM | #2 |
Re: 69 chevy with 250 ?
There could be a dozen reasons , Have you tried to adjust the idle screw on the carb ? ? Are you familiar with these old trucks ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-25-2016, 05:09 PM | #3 |
Im familar with the trucks just not a 250 . I tried to adjust the idle screw but did not help . I was thinking might need a carb rebuild . It was from a high elevation and im at close to sea level not sure if that would make a big difference . Looking to get a manual now
09-25-2016, 05:40 PM | #4 |
i have the haynes book, is it stock carb?
09-25-2016, 06:00 PM | #5 |
Yes it is the stock monojet
09-25-2016, 06:09 PM | #6 |
Does it idle well after start but die after you throttle? could be too strong throttle spring.
with truck idling back what you think is idle screw all way in it should then idle crazy high. ill look in my book to see what carb # it is. from there you can look up manual. in my book its rochester "mv" http://www.carburetor-parts.com/Roch...al_ep_352.html idle speed spec is 480-500 Last edited by Jarvis-69 GMC 1500CK; 09-25-2016 at 06:18 PM. |
09-25-2016, 06:13 PM | #7 |
It will start fine then when i put foot on gas it dies out and then once im moving faster is ok
09-25-2016, 06:19 PM | #8 |
http://www.carburetor-parts.com/Roch...al_ep_352.html idle speed spec is 480-500 |
09-25-2016, 06:22 PM | #9 | |
The Older Generation
That sounds like the accelerator pump is not working. LockDoc
09-25-2016, 06:23 PM | #10 |
Thanks mine is earlier then that ill look for a manual later
09-25-2016, 06:24 PM | #11 |
Lockdoc acc pump on carb?
09-25-2016, 06:28 PM | #12 |
Yes, when you step on the accelerator pedal the accelerator pump squirts a shot of gas into the throttle plates to make up for the extra air entering the carb. If the accelerator pump is not working it will get too much air and not enough fuel which makes it stall out....
LockDoc
09-25-2016, 06:44 PM | #13 |
Sounds like too much air from a vacuum leak!
09-25-2016, 06:56 PM | #14 |
Ok good a couple things i can check
09-25-2016, 06:57 PM | #15 |
Use some propane to check for vacuum leaks. And rebuild the carburetor. Mine had a similar issue and it had a couple vacuum leaks. One around the intake manifold and the other at the base of the carburetor.
I ordered my rebuild kit from mikes carburetor and they have been really helpful. I like the brass float the kit came with. |
09-25-2016, 07:46 PM | #16 |
Well it was a vacuum found a bad rubber cap on one of the nipples replaced it good to go
Thanks for the help |
