1966 283 stock compression??
guys,
I am trying to decide if my bone stock 66' 283 needs to be rebuilt or not, it is currently on an engine stand, my question is this: what compression reading should I be getting on my gauge? I am rotating it by hand. would it be worth putting the starter back on it and rigging it up to use for rotating the motor? |
![]() Join Date: Jan 2011
Re: 1966 283 stock compression??
By hand will be way to slow. You can do a leak down test on the stand. Will give you good info in the condition.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
can no one tell me what i should be seeing for compression on a stock 283 ??
With carb butterflies open at cranking speed a fresh 283 outta show you around 150 psi. P.P. heads may be 5-10 psi higher.
Post Whore
![]() Join Date: Mar 2013
Around 140-150.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Yeah my 283 had true flat tops w/ only two valve reliefs in them & shim gaskets.
