Frame Hole Measurement Help
I'm in the middle of reworking the frame prior to paint and I need to clean up these two wollared out holes at the end of the frame rails...I believe they are for the bumper brackets. I think the previous owner used a torch to cut the bolts and got a little loosey goosey end enlarged the holes. I plan to just weld them up and redrill but I need the location of hole center.
Can someone take a frame measurement in from the end and from either top or bottom, and measure hole size. Thanks in advance.
1971 Chevy C-10 Currently is rust repair Last edited by reb162; 09-25-2016 at 09:22 PM. |
Re: Frame Hole Measurement Help
Weld from the outside towards inside then grind flat and drill out to a notch bigger than 1/2 so 1/2 inch bolts can go on to bolt up the bumper bracket. Or at least that is what I would do.
That's exactly what I did...I welded up the hole from the outside to the center and ground it smooth on both sides. I welded it completely up though since it was so out of round and couldn't even tell where center was.
So now I need measurements for hole centers so i can redrill. Thanks to anyone that can measure their frame.
1971 Chevy C-10 Currently is rust repair |
TTT...hoping someone has a frame they can quickly measure. Was looking to paint my frame this weekend. Thanks again for the assist.
Long bed or short? I never had a factory bumper, but I can go look for the measurements on mine if long bed is OK.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
My rear frame rails look a little different than yours. Here is what I have
Thanks dfwright! Mine is a short bed frame so maybe that is the difference? Surprised that would make a difference in the rear of the frame.
Anyone with a short bed care to get me measurements? Thanks
bump...some short bed frame help here?
bump one more time....was looking to paint frame today but need these holes drilled first...
Please, anyone with a short bed frame please provide locating measurements on the two holes in the picture above! Thanks!
![]() Join Date: Oct 2014
Here's two pics of my SWB 68 frame. Looks like my holes are different than your 71. Bumper bracket is installed so I can't get dimensions.
I say go ahead and paint the frame and drill the holes when you get dimensions. Sorry I couldn't be of more help. Phil
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
