Old 09-25-2016, 11:04 PM   #1
maxinegiebelstein
Question 1996 C2500 Vortec no start
Has spark. Fuel pump is working. All fuses check out good. Starter is good. Drove all day yesterday then last night was going home , got a mile down the street and it died. Cranks but won't start. New fuel filter. Did this before and found the relay to be bad. Replaced the relay worked fine till last night. Relay is working. Help!
maxinegiebelstein is offline   Reply With Quote
Old 10-01-2016, 08:56 PM   #2
TurnNBurn
Re: 1996 C2500 Vortec no start
how much fuel pressure do you actually have they need quite a bit to even fire
TurnNBurn is offline   Reply With Quote
Old 10-01-2016, 10:52 PM   #3
maxinegiebelstein
I don't have a fuel pressure gauge but I Changed the fuel pump, crank sensor cam sensor and ignition module. I got it to start and run . It goes for about a mile or two the starts cutting out like its got bad gas in it. It doesn't .When i changed the fuel pump, I looked in the tank and it was clean. If you turn the key off and back on when it's doing this it starts right back up and goes for another couple of miles and does it again.
Old 10-02-2016, 09:39 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
MAF sensor issue? Have any check engine codes?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
