Old 09-26-2016, 09:26 AM   #1
ubtripn
ubtripn's Avatar
Why not bench bleed on truck?
Couldn't I use the plastic nuts and route the tubes to the reservoir but mount it (not hook up the brake lines) then use the pedal to bleed it? Just curious.
ubtripn is offline   Reply With Quote
Old 09-26-2016, 09:34 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Why not bench bleed on truck?
Yes you can. I've done it several times.
Keith
Convert to disc brakes.
Old 09-26-2016, 09:50 AM   #3
ubtripn
ubtripn's Avatar
Awesome, thank you! I am replacing - again - the mc but one with the booster attached. It shows four bolts and am assuming the install should not be too hard.
Old 09-26-2016, 10:19 AM   #4
ubtripn
ubtripn's Avatar
Do I have to go under the dash with the booster replacement?
Old 09-26-2016, 11:48 AM   #5
davepl
davepl's Avatar
You don't even need to bench bleed if you can lift the rear wheels a bit until the reservoir is closer to level. Bench bleeding is only required, so far as I am concerned, on vehicles with really steep reservoir angles.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-26-2016, 12:31 PM   #6
Overdriven
If you do bench bleed with those plastic fittings, be sure to release the master cylinder slowly after pushing the piston in. If you release too quickly and those plastic fittings don't have a good seal air will get sucked in past them. Pissed me off royally that it kept blowing bubbles out forever until I figured that was why.
Overdriven is offline   Reply With Quote
Old 09-26-2016, 12:54 PM   #7
ubtripn
ubtripn's Avatar
Great point, that happened to me too.
Also,given the angle don't you mean lifting the front of the truck to level out the MC?
Old 09-26-2016, 02:27 PM   #8
cleszkie
cleszkie's Avatar
Perhaps this is true if you want to gravity bleed the system. But bench bleeding on the truck is so easy. Why not just do it?
cleszkie is offline   Reply With Quote
