Old 09-26-2016, 05:54 PM   #1
A-P
Restored Shortened Intermediate Shaft for Van Tilt
Purchased this to use with my Van tilt column, but plans are now to use a dropember with R&P so I don't have a use for this. Restored by fellow board member 70shortfleet - $80 shipped, which is what I paid for it.
A-P is offline   Reply With Quote
Old 09-30-2016, 09:02 PM   #2
c104life
Re: Restored Shortened Intermediate Shaft for Van Tilt
What's the purpose of the shorten shaft, what does it do?
c104life is offline   Reply With Quote
Old 09-30-2016, 09:53 PM   #3
franken
Van column shafts are a bit longer so something has to give...
franken is offline   Reply With Quote
Old 10-01-2016, 09:16 PM   #4
c104life
Does that help if you are trying to shorten the column?
Old 10-02-2016, 12:44 AM   #5
A-P
Yes, that's one of the primary benefits of a van column - you can get tilt, and move the steering wheel closer to the dash.
Old 10-02-2016, 09:03 AM   #6
70shortfleet
70shortfleet's Avatar
If you install a van tilt column into your truck, you have to shorten the intermediate shaft 2 1/2". If you move the van tilt column closer to your dash you will have to shorten the intermediate shaft even more!
70shortfleet is offline   Reply With Quote
Old 10-02-2016, 04:56 PM   #7
c104life
Question if I have a intermediate shaft for a regular 67-72 truck column all have to do is knock the pins out then I can adjust it to the length I need. With the one you already have the pins are all ready out?
Old 10-02-2016, 05:59 PM   #8
darkhorse970
darkhorse970's Avatar
I'm interested, can you tell me what all has been done to this shaft?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 10-02-2016, 09:19 PM   #9
70shortfleet
I took it completely apart, bead blasted it, powder coated it and shortened it to the correct length and packed it full of grease
Old 10-03-2016, 04:46 PM   #10
c104life
Are the pins already out of the shaft or you have to take them out also, in order make the column adjustable
Old 11-07-2016, 09:24 AM   #11
Chevy4Life
Chevy4Life's Avatar
The "pins" are just nylon. Hit them with a propane torch and smack it down to your desired length.
Chevy4Life is offline   Reply With Quote
Old 11-07-2016, 12:46 PM   #12
randy500
deleted comment
randy500 is offline   Reply With Quote
