Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-26-2016, 09:25 PM   #1
lwb82c10
power to manual brake conversion
how do i convert my power brake's to manual brake's, is there a kit i can buy?
it's for a 82 c10 the truck will be full strip
LWB 82 c10 building a street/strip truck. has a 468 with stock 12 bolt.
lwb82c10 is offline   Reply With Quote
Old 09-26-2016, 11:36 PM   #2
Captainfab
60-66 Nut
Re: power to manual brake conversion
No need for a kit of any sort. Simply remove your booster and master cylinder and bolt up a manual master cylinder for a square body. I don't know if manual brakes were an option in '82, so you may have to go back into the mid '70's to find one at your local auto parts store. You may have to fabricate a pushrod for the manual master cylinder unless you can find an OEM one. Maybe check the '73-'87 classifieds here on the forum.
Old 10-06-2016, 05:38 AM   #3
D13
D13's Avatar
Drive up here to Michigan and swap pedals and master with mine. LOL.
Manual brakes tend to have different pedal ratios. Best if you can find a complete truck to pilfer parts from. Most will be from manual trans vehicles, manual brakes tend to be on 'strippos'.
You can buy kits and that may be the way to go if you are going disc on the rear. I 'think' there was a 4 wheel manual disc brake option on early Vettes and possibly later Camaros.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-06-2016, 08:03 AM   #4
regan wilson
regan wilson's Avatar
I've been using the Corvette manual master cylinder for years. I dont even run a portional valve. Works great disc on the front drums on the rear.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 11-04-2016, 12:03 AM   #5
dustin72
dustin72's Avatar
I'm running a Wilwood master/prop valve combo on my '72 with a '67-'72 manual pushrod. Also using a residual valve since I'm running rear drum brakes. Works great.
dustin72 is offline   Reply With Quote
