87 spectra gas tank
I've read on here 87 spectra has the baffle for the in tank pump (ls conversion)
I've been through 2 of them, the first I don't know what they ordered but the second they ordered for an 86 for some reason. I just want to make sure this tank does have the baffle as the new one is supposed to be in this afternoon and I don't want to drive 40 miles for the wrong one so I plan on calling to have them look inside for a baffle Do they have it? |
#2 | |
Re: 87 spectra gas tank
I ordered the GM11C from amazon for my truck and it did have the baffles. This was about a year ago though. This item has been on amazon since 2012, so I think it is the same one. 80 bucks shipped to your door is pretty good.
https://www.amazon.com/Spectra-Premi...keywords=gm11c |
#4 | |
Getting Old; Going Broke
I bought a spectra from O'Reillys for my '87 R10. Yes it had the baffled off spot inside where the fuel pump area was.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Gm11b is the last one they ordered The only other is gm1b
As long as you're after the same thing that's in your truck, the GM1B or GM11B is correct. Now if you're after what goes in an '87 R10, you'll want to look at the GM1C or GM11C tanks.
GM11C GM1C
#8 | |
Those tanks have 2 different dimensions, which will fit an 84? |
One is a 16 gallon and one is a 20 gallon, so it depends on what you're wanting. The 16 gallon will go under a SWB or a LWB, the 20 gallon will go under a LWB. My '87 LWB has twin 16's under it.
Which model# of these would go in a 74 K10?
I went to your links and both descriptions said that they DID NOT have baffeled sumps....
