292 Carb, Intake and headers
I've started rebuilding my 292 L6 in my c10 and was wondering what the best setup as far as carb, intake and headers is. I was planning on going 4bbl and was wondering if I could use a quadrajet carb as I have a few lying around. I'm planning on a set of headers and I don't care about high horsepower as this is just going to be a driver truck. Can anyone tell me if the quadrajet carb will work with an offenhauser 4bbl intake found on summit racing's website.
![]() Join Date: Dec 2009
Re: 292 Carb, Intake and headers
Following
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
![]() Join Date: Nov 2015
As for headers, be careful with long tube headers; they hang really low. I have them and am going to buy Langdon cast iron headers so I can lower it more.
#4 | |
Post Whore
![]() Join Date: Mar 2013
![]() The quadrajet Has been done, but there aren't many who have. Only saw one guy who did it back in 2012 and he said he got 20 mpg with his stock 292. Keep in mind with the offy intake you can only mount the carb with the primaries outboard. This means the back of the carb will be facing the valve cover. I prefer the clifford performance intake as you can mount the carb how you please, but it is more expensive. The runners are larger, but that really doesn't matter unless your concerned with a difference of a couple hp. You will need an adapter to adapt the carb to the manifold. Good headers can be found here: http://www.langdonsstovebolt.com/sto...egory=18665955 And here is the better(IMOP!) intake from clifford: http://www.shop.cliffordperformance....-42-4501WH.htm And the adapter for the intake: http://www.shop.cliffordperformance....b-Adaptor-08-1 His prices have gone up quite a bit since I got mine. In your case the offy would probably be better so things don't get crazy expensive. Here are the shorty tube header he sells. http://www.shop.cliffordperformance....rs-52-0011.htm
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Moderator
![]() ![]() Join Date: Aug 2011
And if you really want to spend some bucks -
The end goal here is for a driver engine that keeps the truck rolling well and is unique. I know everyone seems to put in a smallblock of some sort, so I opted to keep the torque monster. I also need a new cam and lifters as well as rings. Basically want to make this engine do what it should have from the factory. I like those headers TJ, I'd bet they look good on the engine.
#7 | |
Post Whore
Not sure if you're talking about clifford's or langdon's. But here is a picture of clifford shorties on my 292 so you can get an idea. ![]()
