Old 10-08-2003, 12:30 AM   #1
Merl4
Bed Wood
Does anyone have the dimensions of the boards for a SWB. I'm going to mock up the bed wood before I final it. My plan is to go to Home Depot and purchase some pine and have it cut to fit.
I may be making some changes to the tire size and the rear end, so I would like to use like some cheap lumber before I install the good stuff. I believe there are 10 boards that make up the wood.........3/4 thick and 6' long, but I don't know how wide.
Thank you,
Merl
1968 Fleetside
Merl4 is offline   Reply With Quote
Old 10-08-2003, 12:49 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
GMC Paul's has a diagram/blueprint on his site with all of the dimensions you need.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-08-2003, 12:51 AM   #3
pissonNOS
senior member
pissonNOS's Avatar
they all differ in width
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 10-08-2003, 01:10 AM   #4
jorgensensc
jorgensensc's Avatar
I think the board sizes even differs between years, but I can't remember the site I saw that on.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-08-2003, 09:31 AM   #5
mastx
Visit GMC Paul's website at www.gmcpauls.com
I used his diagrams and it worked out great on my longhorn.
Mario
Mario A. Santos
marioasantos@hotmail.com
Luling, Texas
1970 C/20 (in slow progress)
1971 Custom Camper Longhorn
mastx is offline   Reply With Quote
Old 10-08-2003, 10:52 AM   #6
sactoC10
71 DELUX
sactoC10's Avatar
When I get to that stage of my project, I intend to remove the boards that are in place and use them as templates for the measurements. Just a thought, if you can go a short time without using your bed.
sactoC10 is offline   Reply With Quote
Old 10-08-2003, 04:38 PM   #7
john
member #16
john's Avatar
This sheet came with a Brothers wood kit.
john is offline   Reply With Quote
