Old 09-28-2016, 04:02 PM   #1
loujizzel
Tailgate trim install
First off I want to thank a lot of you guys that responded to my post helping me out with questions that I have asked..... okay so here we are I have another question I have a 73 C10 that does not have tailgate trim on the tailgate I want to know what do I need to do to install the tailgate trim on the tailgate that never had the trim..... I don't think it goes on with double stick tape...... can someone please guide me in the right direction I've searched on the form but came up empty mostly because it was talking about tailgates that wall already having tailgate trim on it will I need to buy a tailgate that has it on it?
loujizzel is offline   Reply With Quote
Old 09-28-2016, 05:15 PM   #2
Breeze454
Breeze454's Avatar
Re: Tailgate trim install
No need to buy a tailgate with trim on it. If you are referring to the upper and lower trim, there are screws with nuts on the outer ends and it has double sided emblem tape on the plastic clips that run down the length of it, just like the side trim.
The center trim (embossed CHEVROLET or GMC) has threaded clips on the backside, with screws that enter from the back of the tailgate. (inside bed).
Hope that helps!
Breeze454 is offline   Reply With Quote
Old 09-28-2016, 09:21 PM   #3
TKCR
TKCR's Avatar
Are you talking about the trim in the center of the gate, with the Chevrolet emblem?
You will have to drill holes through the gate and then there are bolts that bolt to the back of the trim.
Old 09-28-2016, 09:35 PM   #4
superdav
How did you get that band to look so good!? I've got one to restore in the future and Ive been hoping someone else would take the plunge and post details before I do
superdav is offline   Reply With Quote
Old 09-28-2016, 11:39 PM   #5
TKCR
TKCR's Avatar
Cleaned it with Goof Off and then I used Brasso. Worked it in with the grain. After removing all the polish, I wiped it down with Skin So Soft Oil. The Chevrolet Emblem is a new OEM part I found on eBay. I was lucky, the trim really wasn't too bad when bought the truck, but a good cleaning & polishing made a big difference. I did the cab molding the same way.
Old 09-29-2016, 09:41 PM   #6
superdav
Mine has a small dent and scratch on the brushed part that will probably be a real pain.
Old 09-29-2016, 10:04 PM   #7
loujizzel
Yes that part .... is there a template for hole placement ?
Old 09-29-2016, 11:51 PM   #8
f.monroe
f.monroe's Avatar
I would find the insert you want to use and make the holes match the insert. I have had several trim panels that had the mounting clips in slightly different places. Some over 1/4 to 1/2 inch off. You wouldn't want to drill holes from a generic template only to find they don't line up with the insert.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
