![]() Join Date: Jan 2002
fact. air --what heater is correct for air ??
im thinking i have seen both heaters w/factory air ?? what is correct or should i say what works better ? thrift or deluxe ? ??? than ks for any input !
![]() Join Date: Mar 2015
Re: fact. air --what heater is correct for air ??
Factory A/C came with the deluxe heater. You could have got dealer installed A/C with the thrift or deluxe heater.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
The heater for factory air trucks is different then the regular heater, has an extra air opening into cab.
Correct. The A/C heater has an extra opening with a blend door. On dealer installed A/C they cut the hole in the heater and added the blend door.
![]() Join Date: Jun 2011
i like the deluxe heater controls because if you go with Vintage Air your original Deluxe controls can be used with the new A/C that way it looks "factory"
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
![]() ![]() Join Date: Apr 2012
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
jon them NOS knobs and stuff -are sure pretty !!!!! im just put a new to the vehicle "dash" in my 64 carryall,now need to get a serpentine belt and accessory drive set-up on it ! probably put a 9 " ford in burb and overdrive trans & paint the thing anyway thanks for posting them pics ! i guess the deluxe heater is the way to go !!!!
