Old 09-29-2016, 11:22 AM   #1
texasag91
texasag91's Avatar
Wheel backspace to tie rod distance
I have a 1991 GMC Jimmy Full Size 4x4. I have a set of old aluminum modular wheels (15x8 3.50 back space) that I am replacing with a set of Pro Comp Series 51 15x8/6x5.5 with 3.75 back space. Bought the new wheels and took them up to a tire place to put them on for me. They said that they would not fit. To close to the tie rod. How much space do you need between the tie rod and the rim? The old aluminum rims fit fine. Would my new rims fit? Pro Comp said they would fit.
Oh, and my Jimmy has no lift. Stock height. Has anyone else ever experienced this situation?
texasag91 is offline   Reply With Quote
Old 09-29-2016, 02:31 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Wheel backspace to tie rod distance
I've got Pro Comp series 97 wheels on my 85 Blazer, 15x10 wheels with 3.75" back spacing. They've been on the truck almost three years now, no problems. The rod ends are close to the inner lip like yours but I can get a fingertip in-between them. Your tire shop is being a little too picky. I'm on my second set of tires since installing the wheels and neither tire shop squawked about the rod end clearance.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-29-2016, 03:03 PM   #3
texasag91
texasag91's Avatar
Thanks. That is what I thought. Someone on another website told me the same thing. Just wanted another opinion. I went and took it back today to get them installed. Also bought two 1/4" spacers and told them to put them on the front just in case. Might take the spacers off when I get home now that you told me this. Thanks again.
Old 10-01-2016, 12:29 PM   #4
Pro Trucks
only thing that could come into play is the clip on wheel weights ....so they only need to watch that when balancing them
Pro Trucks is offline   Reply With Quote
Old 10-02-2016, 10:16 PM   #5
phillipm
Yup had this happen myself!
