09-29-2016, 01:50 PM | #1 |
Another NV4500 Swap Question
Im new to the forum and partially new to these trucks. I found a deal on a NV4500 out of a 94 Chevy 4x4. I've done some research and like the idea of the trans swap and know whats involved from the transforward, but what about the trans and stuff behind it for a 4x4 swap? I have a 1970 K20 4x4 Custom Camper with a 350/SM465/NP205. What would it take to mount my NP205 to the back of the NV4500? I see that the NV4500 shifter is moved back about 4 inches from the SM465, is the trans longer overall? Will this move the NP205 shifter location as well? Any info would be greatly appreciated. I've done some searching and didnt find much info, so I apologize if this has been covered before.
09-29-2016, 10:34 PM | #2 |
Re: Another NV4500 Swap Question
Go to advance adapters web site and get their GM conversion guide as a pdf. It'll tell you more than you need to know. Also, search this site. There are a few threads about users doing the same swap. I think Dirty Larry did a long writeup on a swap into a square.
I think the 205 needs to be machined for a larger input bearing and a new 32 spline _short_ female input shaft installed. The shaft is ~$150. Or snag a round pattern 32 spline input 205--they aren't too common. Around 1985 GM started making 1 tons with SM465, using a 32 spline round pattern 205, but if I recall they used a long input. The short 32 spline input was used on earlier TH400 trucks. A spacer is available to use the long input to mate a long input TC to the 4500. I have one I don't need if you want it for half price. You need a round pattern (4500) to figure 8 (205) adapter (AA, NW fab, etc.) if you stick with your TC. I don't think that trans will bolt to your bellhousing so there's another issue. Some have reworked the existing BH, and others have used the 4500 BH. Some or all 4500 BHs have the opening for the hydraulic lines or release arm on the passenger side. A new BH from AA is ~$350. Then there's the hydraulic clutch release issue. Yours is/was mechanical when stock. I measured the 4x4 4500 in the garage and its 20.5" long. I'm guessing that's longer than an SM465. You'd measure the 465 and the TC adaptor since no adaptor is used on the 4500--it bolts to the TC. If the trans is longer, you're looking at shortening and lengthening driveshafts. The TC shifter needs a new mount. I can snap some pics of the one I have if you want. I think it puts the shifter in the stock location, but mine came from a squarebody. You might check AA to see if its the same for 67-72. The 4500 uses special lube that's expensive to keep the synchros alive and when people use the wrong lube it wipes them. Then there's the 5th gear falling off issue... Dodge and GM 4500s are somewhat different, but I've only had GM so I never paid much attention. GMs can be divided into ~93-94, 95, and 96 up. The first group had a different front bolt pattern, 6.x:1 1st, and no sybchro on reverse. 95 shared a few features of the early and late versions. 96 and up used the Dodge front bolt pattern, a 5.6:1 1st, synchro on reverse. You may want to fact check this since its been a while. That's all I can think of right now. I have a 96 4500, doubler, and round pattern 205 in the garage waiting to be installed so I've done a lot of reading on the subject, as well as trolling scrapyards, buying/selling/trading parts for the swap, etc. Last edited by franken; 09-29-2016 at 10:49 PM. |
10-26-2016, 05:51 PM | #3 |
I am getting parts together for this same project. You can move your engine forward to the 2WD location which lets you move the shifter of the 4500 fwd and keep your same drive shafts. The bell housing selection is still a puzzle to me. I saw where one member here used his SM465 BH by drilling the pattern into the front of the NV. Looked like it worked just fine although you have to assemble the trans and BH together before installing it (like an auto trans). Here is that link: http://67-72chevytrucks.com/vboard/s...d.php?t=611566. I am using a round pattern 205 with a short 32 spline input to keep the whole assembly as short as possible, I'll also move my engine fwd as far as possible for better drive shaft and shifter placement.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
10-27-2016, 10:47 AM | #4 |
I forgot this:
10-28-2016, 01:29 PM | #5 | |
Yes that link was me and my truck is still driven everyday no issues and no complaints about the nv4500.
100:1 low gear! |
01-03-2017, 04:02 PM | #6 |
I just finished a 6.2 diesel repower with a 95 NV4500 and a 82 NP208.
The engine is moved as far forward as possible and I still needed to cut a new hole for the shifter farther back. It hits the seat in reverse. I used the stock NV4500 bellhousing with the external hydraulic clutch. There is a lot of doubt as to whether this would hit the front driveshaft. Since the donor truck for the diesel also had a turbo 400, the NP208 has a 32 spline input shaft with the round pattern. Since I used the original 1971 4x4 transmission mount for a SM465 with some small modifications to accept the 95 mount. I had to heat and reshape the crossmember to clear the front driveshaft. This driveshaft clears the slave clutch.
71 Chevy C10 350/TH350 71 GMC C20 350 (donor truck) 82 Chevy K20 Suburban 6.2/TH400/NP 95 Chevy 4x4 1500 Tahoe 6.5T/4L80E 04 Chevy 4x4 3500 Silverado 6.6T Duramax/Allison 1000 (work truck) 09 Chevy Aveo 1.6L/5 speed manual |
