Old 10-08-2003, 02:51 AM   #1
stringpickin
stringpickin's Avatar
Location: Northern Ca. at the base of the valley just entering the sierra foothills
Exhaust system for 383 stroker
Hello and good day.. Question, I appreciatte the responses. I have a 70 chevy 4x4 with a 383. I put a mild crane cam in it just above the torquer level for most custom cam setups for truck engines. I need a new exhaust system. I used the original 2" system for the last 7 years. I have been told that I should go to 2 1/4" pipe. I am concerned because I have always heard that with trucks if you loose the back pressure, you will lose torque.. Looking for user/or exhaust pro qualified input on this question.. Another place recomended that I go to a performance 2 1/4" dual to single muffler exhaust system with a 3 1/2" single exhaust to improve torque.. What do you think. Appreciatte your time.. thank you..
stringpickin is offline   Reply With Quote
Old 10-08-2003, 08:48 AM   #2
72longbed
72longbed's Avatar
Stringpickin,
In my opinion, the most critical area that affects torque, with regard to exhaust systems, is the first few feet outside the exhaust ports. For a 383 at that level of performance I would think a good pair of 1 5/8" i.d. tube full length headers to a 2 1/2" i.d. dual exhaust that has a cross over ( X pipe not H), around the end of the tranny. For best flow I would follow that X pipe with a true 2 1/2" dual exhaust out the back or wherever you choose to exit. Most performance exhaust pro's say when theres a question about header tube diameter " larger is not always better, and go with the smaller tube when you are in between sizes". Of course, the final application or intended use of the vehicle will play a part in determining header size. I.E. drag racing, circle track, street killer , or just daily cruiser
72
72longbed is offline   Reply With Quote
Old 10-08-2003, 01:34 PM   #3
MikeB
MikeB's Avatar
Yep, 72longbed is right. Over-sized primary header tubes can hurt low speed torque. For a mild 383, 1-5/8" primaries are a good compromise between low speed torque and high speed hp.
From the collector on back, 2-1/2" pipes and mufflers are best. Larger won't hurt torque, but I doubt you'd notice any performance gains.
Heck, my mild 383 has DynoMax Chevelle shorty headers with 1-1/2" primaries, along with 2-1/4" exhausts and DynoMax Super Turbos. It pulls like a freight train off idle and revs to nearly 6000 rpm.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-08-2003, 03:03 PM   #4
stringpickin
thankyou very much for your input. now to get the muffler people to listen to me.. lol....
1970 Chevy 4x4 pickup w/72 running gear. 2 1/2" custom spring lift. Brand New 383 stroker-360hp. by Smeding. Edelbrock EFI Fuel Injection. Rostra Cruise Control, 700r4 conversion. ARB Locker/373.
Disciple of our Father YHVH and the Lord Jesus Christ.
Old 10-08-2003, 03:08 PM   #5
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
Agreed,for my 383 I run 1 1/2" primarys into 2 1/2" pipe with an x-pipe, also pulls ilke a freight train and I rev to about 6500-6800. In my opinion the X-pipe was the best part of the entire system, I ran with the same headers, 3" pipe and no X-pipe for a long time and the difference is like night and day. You can get an X-pipe from Summit for $30 but you have to ask on the phone.
Good Luck
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 10-08-2003, 03:28 PM   #6
stringpickin
Howdy again.. Okay, here is the scoop. Many years back I removed my header system and went to center dump manifolds.. Had my fill of headers after twenty some odd years of dealing with the heat, the continual loosening anc ets. I had hooker 1 5/8 id headers on my truck, but long short story, I got rid of them.. SO, that leads me to this point.. Do you think I should use 2" pipe to the mufflers and then go to 2 1/4 or 2 1/2 for the end pipe. Question about the X pipe.. Being that the X pipe is after the mufflers and the smaller tube at the dumps to the muffler, how could that affect torque.. thanks again..
Old 10-08-2003, 04:06 PM   #7
crazy longhorn
Fabricate till you "puke"
with your stock manifolds, the restriction is 2".....I doubt that adding larger pipe at the rear will help perf, but will tend to make it louder. You can opt for a set of Vette centerdumps, to get to the 2 1/2" pipe size. A set of Dynomax Superturbos are a good deal for the bucks(good flowing, but not super loud). As far as the X pipe, they are better than the old H pipe......but will be d@mn hard to fit on your 4x4(I would stick with the H pipe). At the rear, you can cut the pipe size down a bit(if you like quiet), & you will be far enough from the heat that t wont hurt the flow. My 383 runs 1 5/8 tube Hookers, 2 1/2" pipe to the muffs, the H pipe is 2 1/4, & the tail pipes are 2 1/4(I tryed 3" tail pipes....loud as hell!) Like Mike said, the 383 pulls like stink right off the bottom, & runs to about 6000-6200......its running a 500 cfm Holley 2 brl, & a load of gear! Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-08-2003, 04:41 PM   #8
72longbed
72longbed's Avatar
String,
You have misunderstood where the X pipe goes. Here's the layout from engine to rear of vehicle: 1. Exhaust manifolds or headers. 2. Dual 2 1/2" exhaust pipes. 3. The X pipe is next and within 3 to 4 feet of the rear of the engine!! 4. Again Dual 2 1/2" pipes into 2 1/2" inlet mufflers(2). 5. 2 1/2" outlets from mufflers to same size dual exhaust pipes to exit the vehicle where you choose. The X pipe should be BEFORE the mufflers and where the system gets hot enough to cook spray paint off of the exhaust pipes.
72
Old 10-08-2003, 05:16 PM   #9
crazy longhorn
Originally posted by 72longbed
String,
72
2nd that! not to be goofy, but I did exhaust work for a while.....on the 4x4, it will be tough to install an x pipe around the transfer case without stuff hanging quite a ways below the rails. Even the H pipe did not go in the optimum spot on the 4x4.....it fits better behind the transfercase.....crazyL
Old 10-08-2003, 08:17 PM   #10
stringpickin
Yes, I did misunderstand on the x pipe. I do think it would be to much of a hassle to make that work before the mufflers.. thanks for all of your input.. Now I think I will keep it simple and go from 2" to 2 1/4 up front into some 2 1/4" pro-flows and 2 1/4' pipe from there to behind the tires.. Simple, clean,, and hey, doesn't my 383 make up for that 10 horseys I might be missing by spending a much bigger head ache making the H or X pipe work.. Thanks again guys. appreciatte it a lot.
Old 10-10-2003, 07:24 PM   #11
kickboxr3
Talking
I sure am glad i ran into these post . I just pulled out my mild 350
sbc and will put in a very stout sbc 350 with trick flow head,air gap manifold ,crane cams,w/roller rockers and other goodies.
As stated earlier I would love to stick w/stock exhaust manifolds
but am afraid of losing all of the power i have worked for. Matching the exhaust with motor is not one of my strong points,any ideas or sugestion will surely help
kickboxr3 is offline   Reply With Quote
