Old 09-29-2016, 03:05 PM   #1
michael bustamante
michael bustamante's Avatar
upper control arm assy dilema
on my 99 GMC Sonoma, I need to replace the upper control arms bushings. i have decided to just replace the arms themselves. problem is, the ones i want to buy do not come with the cross bar to mount them to the chassis.
how do you install the mount bars on the new control arms with out taking out the new bushings in the arm?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-29-2016, 07:59 PM   #2
Shady Rascal
Shady Rascal's Avatar
Re: upper control arm assy dilema
I've only worked on the 2wd S10 trucks so your question was intriguing because you're right, they should have shafts.
Now, are you sure your new control arms aren't for a 4x4 S10 ? They use an upper arm without shaft best I can tell.
Shady Rascal is offline   Reply With Quote
Old 09-29-2016, 09:23 PM   #3
oldman3
oldman3's Avatar
Hope this shows up. If it does just scrow down the page till pics of upper control arms show up. Complete with shaft and ball joint, as low as 50.00 to 110.00. OK won't let it load to large. Just go to http://www.rockauto.com/ select Chevrolet, select S-10 truck, select any engine size, select suspension, select control arms, should show you the different arms. Hope this helps...Jim
oldman3 is offline   Reply With Quote
Old 09-30-2016, 12:17 PM   #4
michael bustamante
ill bet you i was looking a 4wd upper ca`s. dangit... i liked the price too..
lol
thanks for your help fellas. im getting on rock auto now
1967custom
Old 09-30-2016, 06:08 PM   #5
michael bustamante
ok what kind of press do i need to replace the upper ca bushings?
1967custom
Old 10-01-2016, 07:51 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I replaced upper control arm bushings on a 99 S-10 and didn't need a press. We used good old fashion brute force. Hammered out the old and hammered in the new. The entire control arm needs to come out of the truck. Make sure you watch your shims when they get loose.
You should get it aligned when your done.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-04-2016, 04:59 PM   #7
michael bustamante
well i finally got er done. i used both my ball joint press and a BFH with a wide socket.
i ended up chiseling out the old bushings. wasnt as bad as i thought it would be. lots o pb blast helped.. LOL
1967custom
