Old 09-29-2016, 11:09 PM   #1
LEEVON
Moderator
LEEVON's Avatar
Fuel gauge problems
I have a new, factory style gauge set with the updated oil pressure and temp. I also have a new fuel sending unit, in a brand new tank, with brand new wiring. Both the gauge and sending unit are supposed to be as original, 30ohm. With a full tank the needle barely reads empty, but it does move from the rest position with key on. The float is not obstructed. I have tried two sending units. Is it possible the gauge is not actually 30ohm as advertised? I called Classic Parts again to be sure. Where does my troubleshooting start?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-30-2016, 01:37 PM   #2
mr48chev
mr48chev's Avatar
Re: Fuel gauge problems
It's pretty easy to test the sending unit with an ohm meter but I've never tested the guage it's self and don't remember seeing a process for checking one.
The only thing I have done in that respect is to connect the sender to the lead from the gauge and ground and run the arm though it's arc to see if the gauge reads so that it matches the position of the sender. I've done that with aftermarket gauges and senders.
My ongoing truck projects:
Old 09-30-2016, 02:21 PM   #3
joedoh
joedoh's Avatar
I wrote up on testing a fuel sender and gauge last time this came up, here is the link
67-72chevytrucks.com/vboard/showthread.php?t=714135
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-30-2016, 10:09 PM   #4
LEEVON
Moderator
LEEVON's Avatar
Thanks fellas! Joedoh that's exactly the dumbed down diagnostic procedure I needed...will be back with results. Leevon
