Old 10-08-2003, 09:56 AM   #1
67chevemall
67chevemall's Avatar
5w 30 /40 oil
What do you experienced truck guys think about running 5w 30 oil in your 350 blocks??
Buddy says it helps on start up in the cold mornings???
I like my 10w 30 Valvoline and think he's nuts??
He just blew his bottom end, and I think this lite oil might have helped out!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-08-2003, 11:48 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Up north, I think you would want to use a lower viscosity. it would be like cold pancake syrup in the mornings otherwise. Down south I use 10-40 in the winters and some times 20-50 in the summers,Its like water if you dont.
sneakysnake is offline   Reply With Quote
Old 10-08-2003, 12:04 PM   #3
VTKidder
In Vermont, all I have ever run in any engine (GM 2.8 V6, 4.3 V6, 3.8 V6, 5.2 V8, 5.7 V8, Chrysler 4.2 I6, Saab 1.8) is 5W30. As said below, it does help on the cold mornings. This past winter we had 6 days in a row where it did not get above -20F Unless you're burning oil to begin with, and are concerned that a lower viscosity oil will burn or leak more, run the 5W30.
VTKidder is offline   Reply With Quote
Old 10-08-2003, 12:16 PM   #4
tom hand
CCRider
tom hand's Avatar
At operating tempature there should be no differance between 10w30 and 5w30. 5w30 should give much better cranking in cold weather. As long as the oil was thick enough to maintain good oil pressure, it had nothing to do with his bottom end failing
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-08-2003, 03:58 PM   #5
1972ChevyGuy
1972ChevyGuy's Avatar
Im running SAE30. I switched over from 10w-30. I have more oil psi now and it runs a little better
1972ChevyGuy is offline   Reply With Quote
Old 10-08-2003, 05:22 PM   #6
73stepside
73stepside's Avatar
i run 5w30 in my camaro and it has 133,000 and still running strong. by the way it is the preferred oil for that engine by gm
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 10-08-2003, 05:40 PM   #7
casey
casey's Avatar
I heard theres a new oil out for high mileage motors, whats that all about? just a thicker oil I presume
casey is offline   Reply With Quote
Old 10-08-2003, 07:43 PM   #8
mooneyes
mooneyes's Avatar
...the whole reason all the car companys started using 5w30 is the had to get a certain mpg out of all the vehicles they built so going to a 5w30 oil didnt gain much gas milage but just enough in every car/truck they sold to add up to alot on paper ...start up is one of the hardest things on an engine and the 5w30 is fine when an engine is new but get some miles on it and some clearence in the bearings and the 5w30 aint quite enough on start up..imo....remeber the only thing keeping your crank from grinding away at your bearing is the oil...and i just dont trust 5 weight on start up
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 10-08-2003, 09:21 PM   #9
Class of 69
Class of 69's Avatar
I used the recommended 5-30 oil in one engine I owned. Course it was a POS Ford, but the crank went out at 50,000 miles! I've lived in MN all my life, and have never run anything but 10-30 in the winter since the Ford failure. I use 10-40 in the summer. I have a 89 S-10, 4.3 with 140,000 miles, and my 95 K1500, 5.7 with 112,000 miles. Neither uses oil between changes. I also use the biggest rated battery that will fit my vehicles to avoid any slow cranking from winter cold, or summer from the heat. I haven't needed a jump start in 22 years. The oil company's can quit making 5-30, as far I'm concerned.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 10-08-2003, 09:59 PM   #10
mooneyes
mooneyes's Avatar
i agree completly..i usually run 10w40 except in my 70 cause the old 305 has a pyle of miles and the crank is untouched and been in 3 different motors so i have to run straight 50 wt plus some stp...wonder how much longer the old girl will last?????...LOL
78 caprice project
Old 10-08-2003, 10:25 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I understand the arguments favoring 5W oils, but personally, I feel safer with 10W30 in the sump. If I lived where it got Gawd-awful cold in the winter, I'd use synthetic oil, which flows better when cold. Just my .02
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-08-2003, 10:45 PM   #12
73stepside
73stepside's Avatar
the 5w30 will flow faster than 10w30 at start up and in cold weather.
04 GMC Sierra RCSS
70 CST LWB
Old 10-09-2003, 08:55 AM   #13
67chevemall
Some good debat!
Lots of info!
I'm 10w 30 Valvoline till it dries up!
Or Bush guy makes it illegal!LOL
Cheers
Any one else?
Old 10-09-2003, 02:03 PM   #14
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Out here in Sunny Ca where I live it seldom gets below 40 F
I have always used straight Valvoline 30 in MY truck.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-09-2003, 02:24 PM   #15
stepn67
Junior Member
stepn67's Avatar
Whats the difference in 10W30 and srtaight 30. I've learned alot from you guys. My wifes truck is an '03 and the owners manual recommended 5W30, but on the last oill change I used 10W30 and was a little worried about it. You guys have now put my mind at ease.
stepn67 is offline   Reply With Quote
Old 10-09-2003, 03:10 PM   #16
SuperCheyenne72
SuperCheyenne72's Avatar
1972ChevyGuy... I agree with you 100%
I used to run 10w-30 Penzoil for many years. I also convinced my girlfriend to do the same in her 2000 Nissan Altima. Months later and old coot (no offense to any coots out there) strongly advised me to 1) stop using any 5 or 10 weights because they're like water and will be prone to slipping past the seals, burning off... or something like that and 2) to switch over to either Valvoline, or Castrol because they're the only oil companies that don't use tar (or the same stuff they pave our roads with as he referred to) in their oil, and why on earth would I want to put tar in my engine!?
I asked how the heck he knew I was running 10w-30 in my girlfriends car and he just exclaimed that he could "hear" it... sure enough as I listened closely... the engine had a weak "tingy" sound as it idled. I immediately changed her oil to SAE 30 Castrol and not only did her engine go noiseless... but her mileage went up an extra 2 miles to the gallon.
I was impressed and convinced... I then changed out my oil with SAE 30 Castrol and although my mileage seems about the same... I don't burn oil anymore... I used to have to pour a quart in every 2 fillups (once a month)... but now the habit of just carrying an extra quart of oil with me is just that... a habit.
Keep in mind this is all in Texas... but if ChevyGuy is in NC... then who knows?...
'72 Super Cheyenne LWB
  • 350 V8 w/ TH400
  • MSD Pro Billet HEI Dist. w/ Splitfire plugs
  • Edelbrock Performer Intake Manifold and dual exhuast glasspaks
  • Edelbrock Performer 750 cfm
SuperCheyenne72 is offline   Reply With Quote
