"something witty here"
rear sport bumper bracket pic
does anyone have a picture from the inside frame rail of their rear sport bumper brackets installed on the truck? Trying to install my bumper and the holes wont line up, trying to see what Im doing wrong, its one a severe angle not sure if thats right or whats wrong.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
Re: rear sport bumper bracket pic
The bracket on the inside goes straight back and the one on the outside is at about a 45 degree angle. Are you sure you have the back brackets and not the front ones, they are different.
69 Chevy 4x4 383 Power ![]() |
thank you, I cant quite see, how many bolts are going through the bracket and frame?
#4 | |
Not just front and back are different. There are at least 2 different sets of rear brackets. One set fits all longbed 2wds and shortbeds with coils. The other set fits all 4wds and shortbeds with leafs. At least that's what the counter guy told me when I bought mine a few days ago. On my 2wd longbed with coils, there were 2 bolts per side, and the holes were already there. Same holes as the stock step bumper. BTW, don't tighten any bolts until you get them all started ( including on the bumper ) or they won't line up. |
That's good to know... I was told different.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#6 | |
I took this bumper off a 2wd longbox but it does have two holes lining up on each side of the 4wd frame it looks like it will work. but I may just have to order new brackets...
for 67-72 chevy -GMC there is 4 types of bumper brackets avalible for the front bumper and 2 styles of bumber brackets for 67-72 rear bumpers brackets ..... As per counter parts part numbers that are avalable.
![]() Join Date: Dec 2012
Here are mine. The brackets sandwich the frame with the inner a bit longer with two holes. I had no help, so I eased mine up with a floor jack and got it mounted after restoring things.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
I found my set on Ebay. Wish seem this a week ago when did mine. A lot of test fits. Ha ha. Oh well had fun doing it.
