Old 09-30-2016, 07:00 PM   #1
Bandit130
Bandit130's Avatar
74 C10 TH 350 Speedo Cable Question
There is a housing at the end of the speedo cable that connects to tranny. What is this for and what is the name? I have dealt with speedo cables before, but they were directly connected to tranny and no housing between. Also, does the housing have to be there?
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 09-30-2016, 09:09 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: 74 C10 TH 350 Speedo Cable Question
Little offset aluminum box? If so its a factory ratio adapter. HTH Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 09-30-2016, 09:35 PM   #3
Bandit130
Bandit130's Avatar
Yes looks like a small aluminum box or gearbox. Thanks for the info. Does it have to stay or can it be removed and connect cable directly to trans?
Mopar by Birth
Chevy by Choice
Old 10-01-2016, 12:32 AM   #4
Jaysonb
Jaysonb's Avatar
If you clean it up, the ratio should be stamped on it. If it's 1 to 1 you should be able to remove it, if it's any other ratio, it will throw off your speedo if you remove it.
Jaysonb is offline   Reply With Quote
