Drag Link 2wd vrs. 4wd
I would like to know if there is any difference's in the 1/2 ton 2wd from the 1/2 ton 4wd trucks drag/center links. Here is a ruff drawing of what mine measures out to. Thanks in advance for any help.
Born Psycho
![]() Join Date: Feb 2001
2wd vs 4wd are totally different. even the steering box sector shaft is different.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Re: Drag Link 2wd vrs. 4wd
Even 1/2 ton VS 3/4 ton 2wd trucks are different. Hole taper is different.
'68 C10 SWB '85 K30 Blazer |
I should have said my truck is a 68 C10 6cyl if that matters and non power steering if that also matters. Also is the Angles different at the points where the Pitman Arm & Idler Arm & the Tie Rod Ends are in relation to each other from the 2wd to the 4wd Trucks, Thanks again in advance
4WD doesn't use parallelogram linkage but rather push - pull with toe rod
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
