09-30-2016, 09:25 PM | #1 |
4l80e low hump trans cover.
I have read that some folks have installed a 4l80e into c10 with a low hump trans cover. I know it will be a tight fit. But my question is has anyone installed a floor shifter with the low hump also. My 67 has 3 on tree and I want to put a floor shifter in with the 4l80. Please post any info or pictures if you have any.
10-02-2016, 08:17 AM | #2 |
Re: 4l80e low hump trans cover.
I installed a 4l80e in my truck with a lokar shifter and had to cut the top of the tunnel and it's a low hump
10-02-2016, 09:54 AM | #3 |
I know of 2 with the 4l80 installed with. Low hump. Mine is one. I have a cable floor shifter but it's mounted in my console. The other does use the stock column shifter
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-02-2016, 08:30 PM | #4 |
How bad are your Cab Mounts?? It really depends on the shifter (Lokar & Gennie) styles that mount to the trans case can take up a lot of room, With a Cable Shifter.....It doesn't really matter.
10-02-2016, 08:48 PM | #5 |
OK thanks guys, I like the look and style of Lokar shifter and the way it mounts to trans. But that is why I asked , looks like it will take some room for it to work. I have replaced all cab mounts already.
