installing factory style cigarette lighter
I am installing a new factory style cigarette lighter our truck never had one and I want it to charge cell phones maybe it wont work that way.
Anyway does anyone know where to wire it to? I am assuming one wire to ground and one to the un-fused plug on the fuse block? The lighter came with slide on connectors and I am just wondering if there is a factory spot I am missing they plugged into? Thanks Chad |
#2 | |
The Older Generation
Re: installing factory style cigarette lighter
On the fuse block you should have a terminal labeled "Cig" as shown in the picture..... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-01-2016 at 10:16 AM. |
Can I ask where you got the lighter, and how is the quality of the unit?
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
LMC and it seems nice
Is there a grounding terminal somewhere
the cig lighter grounds to the dashboard where it mounts no external wire for ground
Mine is grounded to the glove box. The repo lighter assy had a plug on it for ground.
1982 K10 SWB 1987 V20 - Sold - Doh! |
I have a cig lighter from a truck being parted out on here. I want to install it so I can do the same thing as this thread author. However, my dad used the cigarette lighter delete to put in a manual choke.
I would like to find a manual throttle dash and reroute the choke cable to the throttle knob OR put it over on the left over the brake release. |
ok I got it wired up single wire to fuse box and grounded by how it connects to the dash and it works. the lighter also has a blue wire that connects to a light inside the lighter. I need to find a location to hook the wire possibly factory location where it feeds off the power when you have the light switch pulled. Is there some extra plugs somewhere for that under the dash also?
Thanks |
I believe your a/c/heater control ought to have a light you can piggyback off of
that would make since it might have I think the light for that is burnt out and I forgot about it! Thanks
Chad |
6>8 Plugless........
![]() Join Date: Sep 2007
The ac heater control head does have 2 lamps so you could tie in to the LH side wire for your cig lamp.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
