Old 10-02-2016, 10:08 AM   #1
beanious
Question 71 K10 Question ???
Hello all, I have a 71 K10 and I noticed something that looked peculiar yesterday. The font leafsprings look a little off at the shackeles. It looks like they are tilted inward, not a huge amount but enough it doesn't look right. I measured the distance between the leafsprings at the front 29 3/8" and rear 28" and they are off by more than an inch, making me think that the shackles are turned in an inch. I was wondering if anyone out there can verify the distances and confirm if this is normal or not. Thanks for the help!
Bryan B.
beanious is offline   Reply With Quote
Old 10-02-2016, 10:20 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 71 K10 Question ???
Just to clarify, the truck is an original 4wd per the vin and not a converted 2wd truck?
Old 10-02-2016, 10:27 AM   #3
beanious
DeadheadNM, yep it is a K10 confirmed by VIN. Thanks for the help
Old 10-02-2016, 12:54 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My '72 K20 measures 27 7/8" between the front hangers -- 27 3/4" between the rear shackles.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-02-2016, 02:14 PM   #5
beanious
Mike, thanks for your help. I figured that there was something weird about the way it looked. Thinking it through, I naturally thought the leafsprings should be evenly spaced in order to have proper steering-handling.
The only thing I think might help the problem is to add another crossmember in order to restore and retain the correct alignment. I was thinking that a crossmember from a 60-66 chevy truck might just do the trick. It would mount in the correct place, but I'm not sure that the dimensions will work for our trucks. I'll probably just have to buy one off ebay and give it a try.
Thanks once again for the measurements.
Bryan B.
Pic of 60-66 bellhousing crossmember:
Old 10-02-2016, 06:13 PM   #6
RedRoad
RedRoad's Avatar
Maybe the tubular crossmember is pushing the frame apart? Possibly a dodge front axle also pushing/pulling the springs around?
RedRoad is offline   Reply With Quote
Old 10-02-2016, 08:59 PM   #7
junksaver
The crossmember you are looking at is for a manual transmission truck and it supports the bellhousing. It won't work on your truck because you have an auto trans.
I think your problem may be worn spring eye bushings and shackle hanger bushings. Remove the shackles and check your bushings. If any are worn you should just replace all of them.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 10-02-2016, 09:08 PM   #8
Jeff's bowtie's
Looks like in the first pic the spring bushing is wore out the bolt looks lower on the right side of the spring causing the spring to shift inward and tilting the shackles
Jeff's bowtie's is offline   Reply With Quote
