Best place to clip the in-cab harness ground
Looking at the books, it's difficult to tell where the harness ground wire was clipped (the end is a sheet-metal U-clip, not a spade terminal). Does anybody know what the stock location was or what the best place would be?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Back in the sticks
Both of mine clipped to the back of the dash metal right next to the steering columns. I just made sure there was a bare spot of metal to clip it to. Squash the clip a little too so it fits nice and tight. That should do it. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#3 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
CCRider
Those little clips are the cause of most dash problems. Remove it a replace it with a good ring terminal and screw it down were you can't see it...you will be the only one that knows and your dash will work perfecty
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
#5 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#6 | |
Resident Curmudgeon
![]() Since Pallalin was inquiring about correct location and red71cheyenne's post did not specifically state which side of the column I thought I'd clarify to be HELPFUL. And YOUR point? ![]()
My other Love
put a ground strap from the cab to the frame also, it helped my truck, because of all the paint and dirt and whatnot collecting on the truck through the years
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Two straps cab to motor (where the battery is grounded), one cab to frame, one frame to motor. Instead of worrying about grounding the bed, I'm going to ground the tailights directly.
Thanks for the info, guys. I may in fact screw the ground down. I had had no problems with it prior to tear-down; I just couldn't remember where it clipped. The details slip away after so many weeks. . . .
