Old 10-02-2016, 06:21 PM   #1
Roarinrat
Wanted: Door relay spring
Hi guys
I wonder if anyone of you wonderful people can help me out.
During my 57 gmc rebuild I have found that the drivers door relay has a snapped spring.
Its the coiled one, and can be removed by opening up the housing.
It will be near enough impossible to get one here in the UK, so any able to source me one?
Thanks in anticipation.
Steve
Roarinrat is offline   Reply With Quote
Old 10-02-2016, 08:44 PM   #2
mr48chev
mr48chev's Avatar
Re: Wanted: Door relay spring
I'm not quite following what you are asking for. Relay for electric door openers, relays for electric windows? Relay for dome light when door opens? Or ????????????????
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 10-03-2016, 01:25 AM   #3
Roarinrat
The "door relay" is the mechanical mechanism that the interior door handle attaches to, that converts the rotary motion of the handle to linear push rod action to operate the door lock.
It's called a door relay in LMC's and Brothers' catalogues.
Hope that helps.
Old 10-03-2016, 07:07 AM   #4
Michel
Michel's Avatar
Hi Steve,
I had the same problem of spring broken on the door relay of the passenger side of my truck. I made long searches without finding the spring alone. Finaly bough a replacement door relay 'assy' from LMC...
Just my 2 cents
Michel
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle
Michel is offline   Reply With Quote
