Old 10-02-2016, 06:45 PM   #1
gable74
gable74's Avatar
Sloppy 4wd shifter
Still going over stuff on the GMC and getting a few things straightened out. Needed a new RVM, installed a new voltage reg., new battery terminals, added second battery to complete the dual batt. setup, etc. I noticed while checking things out that the 4wd shifter has a good deal of play in it both right/left and fwd/bkwd. It still shifts into all gears fine but it has a lot more play in it than the Chevy. The Chevy actually has zero play in it. I pulled the 4wd boot off and looked around in there and it looks like there is a 5/8 bolt holding the shifter pivot point to the tranny housing. The play looks to be coming from that pivot point but the bolt holding it on is tight.
Any feedback before I pull the shifter out to examine?
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 10-02-2016, 09:54 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Lightbulb Re: Sloppy 4wd shifter
i've made shims to tighten up the shifter from plastic milk containers, they worked great and last for years. if it's really bad you can have it bored out and a brass bushing installed by a good machine shop.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-02-2016, 10:17 PM   #3
gable74
gable74's Avatar
Interesting.......care to elaborate a bit for someone who has never done this before .
Old 10-02-2016, 10:41 PM   #4
bluek5
bluek5's Avatar
I would pull the pivot bolt out to verify that it is correct. Someone may have installed a bolt without a shoulder for the shifter.
bluek5 is offline   Reply With Quote
Old 10-02-2016, 10:55 PM   #5
gable74
gable74's Avatar
That's probably a good idea. Where can I pick up a new bolt in case I find this is the issue?
Thanks,
Old 10-02-2016, 11:00 PM   #6
bluek5
bluek5's Avatar
I doubt the dealer would still have them. You should be able to find one with a WTB thread.
Old 10-02-2016, 11:06 PM   #7
gable74
gable74's Avatar
Okay, thanks.
Old 10-03-2016, 12:08 AM   #8
gable74
gable74's Avatar
Just noticed the grease fitting on those bolts in your picture. The bolts I have definately dont have a fitting so I bet I need the correct bolt. Thanks for the picture. I am going to use your picture in my WTB thread if you dont mind bluek5?
Old 10-03-2016, 06:56 AM   #9
These trucks didn't have the grease fitting, but the later ones that did will interchange.
Old 10-03-2016, 09:46 AM   #10
joeydurango
joeydurango's Avatar
Doesn't take much wear in the lever's bolt fitting to make for some real slop. While you have the current bolt out of there, take a look at the condition of the lever itself...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 10-04-2016, 12:15 PM   #11
72again4x4
72again4x4's Avatar
Hi Gable,
Are you still in need of this bolt? I have one you can have if you like. I went with twin stick cable shifters for mine and don't need it. Send me a PM with your address and I'll get it in the mail.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 10-04-2016, 12:33 PM   #12
jeffahart
jeffahart's Avatar
You need to pull the shift lever and inspect it. You may need to have it honed, they get a bit raunchy under there. In that case you would need a sleeve bushing anyway. If you need to hone it then go online an find a shoulder bolt to the next oversize you hone to. Then you will have a nice fit. I did not hone mine, I pounded in some brass bushings and put in a standard bolt. I only put in about a 3/8" sleeve on each side of the shift lever hole. Works for now. I will do it up right one day.. maybe! Just pointing out that a new bold alone may not get you there.
White K20
jeffahart is offline   Reply With Quote
Old 10-04-2016, 12:35 PM   #13
gable74
gable74's Avatar
Thanks Roger! I already have one coming but I think there were a couple guys in my WTB thread looking for one.
http://67-72chevytrucks.com/vboard/s...d.php?t=719266
Old 10-04-2016, 02:00 PM   #14
CUSTOM/10
CUSTOM/10's Avatar
Pm sent to Roger ( 72again4x4 ) about shifter bolt !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-05-2016, 10:33 AM   #15
jeffahart
jeffahart's Avatar
My quick straight bolt with bushing fix works so nicely that when I have time I will get my shifter honed and get some nice plugs.
You can get a nice new strong bolt and get better movement from nice bushings.
Just in case someone reads this in the future and wants some ideas.
http://www.bronzebushings.com/plug-graphite.html
White K20
