Old 10-02-2016, 10:51 PM   #1
Robznob11
Robznob11's Avatar
FS Lower shock brackets. Fresh powdercoating
I have a set of old style shock brackets. They have fresh gloss black powder coat. I was going to use them to do a custom set up but changed directions. 70$ shipped in lower 48
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-04-2016, 11:06 PM   #2
Robznob11
Robznob11's Avatar
Re: FS Lower shock brackets. Fresh powdercoating
Open to offers and trades.
LED TAILS
Old 10-19-2016, 11:35 PM   #3
Robznob11
Robznob11's Avatar
I can do 60 shipped....if someone is interested
LED TAILS
Old 10-30-2016, 11:07 AM   #4
Robznob11
Robznob11's Avatar
Bump
LED TAILS
Old 11-11-2016, 12:24 AM   #5
Robznob11
Robznob11's Avatar
Total
LED TAILS
Old 11-14-2016, 12:22 AM   #6
Robznob11
Robznob11's Avatar
Open to offers
LED TAILS
Old 11-28-2016, 08:34 PM   #7
Robznob11
Robznob11's Avatar
1st 40$ takes them shipped
LED TAILS
Old 11-28-2016, 09:23 PM   #8
randy500
Are those for coil spring rear? Looks like the one on the right doesn't have a full hole for the shock to mount, can you verify with a better pic?
randy500 is offline   Reply With Quote
Old 11-28-2016, 10:29 PM   #9
Robznob11
Robznob11's Avatar
Yes they are for coil spring and they are complete. The white foam is covering that part. I'll try and get a better pic
LED TAILS
Old 11-30-2016, 12:17 AM   #10
Robznob11
Robznob11's Avatar
Here you go randy.
LED TAILS
Old 11-30-2016, 01:49 AM   #11
randy500
Thanks Rob, I will go out and look at mine in the morning and see if I need them.
Old 12-16-2016, 12:14 AM   #12
Robznob11
Robznob11's Avatar
Bump !
LED TAILS
Old 12-26-2016, 10:33 PM   #13
Robznob11
Robznob11's Avatar
Ttt
LED TAILS
Old 01-07-2017, 01:40 PM   #14
Robznob11
Robznob11's Avatar
Bump
LED TAILS
Old 01-07-2017, 01:47 PM   #15
GR8-68
GR8-68's Avatar
What did these come off of ? I have never seen this style
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-07-2017, 02:07 PM   #16
michael bustamante
michael bustamante's Avatar
i noticed that also and was wondering what these were out of?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-07-2017, 02:12 PM   #17
Robznob11
Robznob11's Avatar
These are the first version 63 trailing arm mounts.
LED TAILS
Old 01-07-2017, 02:43 PM   #18
randy500
I have a set of the same type on my truck...I have seen them in the past too and I think they are aftermarket and generally used with air shocks.
Old 01-07-2017, 02:46 PM   #19
Robznob11
Robznob11's Avatar
Wink Re: FS Lower shock brackets. Fresh powdercoating
Im pretty sure they are stock 63-66 brackets. Some people seek them becaus they can be drilled for a custom shock relocation. One thing for sure they are much stouter than the kind with a single bolt sticking out for the shock to ride on.
LED TAILS
Old 01-10-2017, 06:20 PM   #20
46stude
I'll take 'em if they'll fit a stock coil sprung '72 2wd 1/2 ton, if they're still available.
46stude is offline   Reply With Quote
Old 01-10-2017, 06:24 PM   #21
Robznob11
Robznob11's Avatar
They are avaliable still. I know they should bolt to any trailing arm truck.
LED TAILS
Old 01-10-2017, 06:39 PM   #22
Robznob11
Robznob11's Avatar
Upper Shock Relocation 1963 through 1972 - The 1947 - Present Chevrolet & GMC Truck Message Board Network
http://67-72chevytrucks.com/vboard/s...d.php?t=451200
Here is a thread of a fellow doing some relocation you can see how they mount. Should work for stock or modified set up. I was going to to flip them side to side and run outboard shocks . But i could no due to very wide tires.
LED TAILS
Old 01-10-2017, 06:47 PM   #23
michael bustamante
good idea
1967custom
Old 01-10-2017, 07:01 PM   #24
Cheyenne1970
I'll take them if 46stude passes.
Cheyenne1970 is offline   Reply With Quote
Old 01-10-2017, 07:02 PM   #25
46stude
PayPal sent.
My Cheyenne is stock height with worn out air shocks. I'm fixing to replace the shocks w/ a set of HiJackers & wasn't real fond of the factory single sided shock mount. These will remedy that problem.
