Old 10-03-2016, 12:05 AM   #1
airbrushguy
Highest ratio gears usable??
I would like to change my ring and pinion to higher (lower numerically) ratio. I have a 350-300 hp with auto. Truck is almost never used for hauling and winds a lot on highway. I think it has 4:11s now.
Anybody change theirs with success?
airbrushguy is offline   Reply With Quote
Old 10-03-2016, 09:47 AM   #2
biketopia
Re: Highest ratio gears usable??
3:08s is what most these trucks came with stock. A lot of guys like 3:73's, give a little more umph off the line but doesn't send your rev's through the roof. I have 3:73's in my truck and love em.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-03-2016, 09:49 AM   #3
joeydurango
joeydurango's Avatar
I have 3.73's in my 4x4, but if I were driving a lot of highway miles over 55mph, I'd probably look into a set of 3.42's.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 10-03-2016, 11:48 AM   #4
bigmac73
bigmac73's Avatar
is a 3:55 available for the 12 bolt? it is a good ratio
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-03-2016, 02:20 PM   #5
airbrushguy
Yeah I agree, I have seen 3:42s offered and as long as it wouldn't make the automatic trans take forever to shift, I'm going to do it!
Old 10-03-2016, 03:25 PM   #6
Mrturner1
4.56's with a Gear Vendors over/underdrive, perfect lol
Mrturner1 is offline   Reply With Quote
Old 10-03-2016, 03:54 PM   #7
truckster
truckster's Avatar
You don't mention your tire size. That's a critical component in determining what your final drive ratio will be.
truckster is offline   Reply With Quote
Old 10-03-2016, 04:20 PM   #8
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I put 3.42's in mine and with OD it works well on the interstate. If you have 4.11's now, you will have to change your carrier to a 3 series carrier. Someone else can chime in on that one...
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-05-2016, 11:10 AM   #9
airbrushguy
Smitty
Could somebody explain that more?
Old 10-05-2016, 11:21 AM   #10
HO455
Post Whore
HO455's Avatar
This is a good reference showing tire size, gear ratio and expected use/results.
http://www.4wheelparts.com/off-road/...-diameter.aspx
RIP Bob Parks.
Old 10-05-2016, 11:58 AM   #11
Bigdav160
Bigdav160's Avatar
Because as the pinion gear gets smaller the ring gear mounting on the differential case has to move over.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-05-2016, 12:01 PM   #12
AnotherWs6
AnotherWs6's Avatar
Tire size is important, agreed. What do you have OP?
Think I've got a 235/70/15 along with 3.08's. Allows me to cruise at 70mph no problem.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 10-05-2016, 07:58 PM   #13
firedemon
you can get an adjustable modulator valve and change the shift points but it should be fine
firedemon is offline   Reply With Quote
Old 10-05-2016, 08:10 PM   #14
firedemon
as the gear ratio goes up or down the size of the gears go up or down so the carrier needs to get sized to fit the ring gear series 4 carrier does 373 to 411 or higher and series 3 carrier goes from 308 to 342 . I can never remember witch but one set wont fit the carrier at all and the other set will slide down the carrier but the bolt holes will be way off
Old 10-05-2016, 10:00 PM   #15
airbrushguy
Thanks for clearing that up.
