10-03-2016, 12:16 AM | #1 |
WTB 4WD shifter pivot bolt for 1971 GMC K2500
Title says it. Its the bolt that pivots the shifter on the tranny case. Looks like THIS.
Thanks, Jimmie
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX Last edited by gable74; 10-03-2016 at 12:45 PM. |
10-03-2016, 04:36 AM | #2 |
Re: WTB 4WD shifter pivot bolt for 1971 GMC K2500
i have a new gm one , i'll include a new wave washer if i can find them. 30.00 shipped
10-03-2016, 06:51 AM | #3 |
I'll get inline for this if Jimmie doesn't take it, or if you have another one !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
10-03-2016, 07:37 AM | #4 | |
Thanks!
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX |
10-03-2016, 07:42 AM | #5 |
Jimmie, just out of curiosity - did you need this to fix the 205 shifter rattle or was yours missing or something else? Mine rattles like a banshee and I haven't had a chance to crawl under and check it out. Figured something like this might be the culprit...
10-03-2016, 07:50 AM | #6 |
Hey Jocko, I tried everything else and nothing worked. I figure this has to be it...lol. Its going to be a pain to get out cause the exhaust is right there but I will post up with results as soon as I do.
Jimmie
10-03-2016, 07:57 AM | #7 |
Thx Jimmie - I'm pretty sure I need one of these also. Lookin fed to hearin the results.
10-03-2016, 06:19 PM | #8 |
pm sent gable74, most of that rattle is the missing wave washer. mine are to small for this application. mine fit the rockwell 221. i have a box of new ones. i will send pm's to CUSTOM/10 and jocko if more turn up
10-03-2016, 07:03 PM | #9 |
What size wave washer is required?
10-03-2016, 07:20 PM | #10 |
3/4 like the washer, this is a 3 wave washer. i gotta find where i bought these and let you all know here. this place had nylon bushings also for some shifters
10-03-2016, 07:32 PM | #12 |
yes sir!!! i have the same brand but mine are 5/8.
10-03-2016, 07:34 PM | #13 |
Okay cool. I bought a few of them so I should be good.
Definitely 3/4" right? The bolt head on mine was 5/8". Thanks for the help!
10-03-2016, 07:41 PM | #14 |
this is an upgraded bolt i believe,
10-03-2016, 07:44 PM | #15 |
10-03-2016, 07:45 PM | #16 |
if for some reason this bolt is wrong, i will gladly refund you. but i believe its correct. talk to you 2moro
10-03-2016, 09:11 PM | #17 |
All about them K’s
I believe that bolt was standard on the later 205s. I've seen the later 205s with the grease zerks on them. It should work with a 69-72 as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-04-2016, 07:26 AM | #18 |
Just an FYI the 5/8 head bolt is a 7/16 thread so your shifter will have 2 plastic bushings and a metal insert they will need to be removed to use this bolt.
10-07-2016, 04:51 AM | #19 |
1400913 SHIFT LEVER BOLT $95.00. my resources found this to be only one left, gable74 you got a deal!
10-07-2016, 05:40 AM | #20 |
Lol, thanks. Should be here today.
