Old 10-03-2016, 01:31 AM   #1
Lefkada
First motor start, terrible knocking
Fired up the motor today for the first time to hear a horrendous, fast-paced knocking. We quickly shut her down and pulled off valve covers, but didn't see anything obvious.
Engine was partially rebuilt. I pulled the heads off for a valve job but didn't touch the cam or pistons. This sound did not exist prior to tear down.
I'll be pulling the pan tomorrow but was wondering if anyone knew immediately what may be producing this knocking?
https://youtu.be/VAxGZIOPXL0
1972 C/20 LWB, 350/350
Lefkada is offline   Reply With Quote
Old 10-03-2016, 07:23 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: First motor start, terrible knocking
Did you soak / fill the lifters before you installed them ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-03-2016, 08:38 AM   #3
cruisinthe34
cruisinthe34's Avatar
Total shot in the dark, but you might check as a last resort that the fly wheel is tight. I built a flathead once and the bolts on the flywheel were just a little too long and bottomed out. Could be the flywheel needs tightening.
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 10-03-2016, 08:46 AM   #4
truckster
truckster's Avatar
Are you missing any nuts? A nut bouncing around on too of a piston sounds just like that. (Ask me how I know.)
truckster is offline   Reply With Quote
Old 10-03-2016, 09:17 AM   #5
geezer#99
geezer#99's Avatar
Or the sound of a valve touching a piston!
Likely valve adjustment done wrong.
geezer#99 is online now   Reply With Quote
Old 10-03-2016, 09:34 AM   #6
Lefkada
I did soak the lifters for a couple hours before installing. Then the motor sat for a couple months before firing up.
Old 10-03-2016, 09:36 AM   #7
Lefkada
We aren't missing any that I know of and were extremely careful to avoid this when putting everything back together. I would be really surprised if this was the culprit but it's worth looking into.
Old 10-03-2016, 09:38 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Did you pull the distributor and prime the oil system before firing?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-03-2016, 09:39 AM   #9
Lefkada
Is there a way to check this without pulling the motor? The valve job was done at a pretty reputable machine shop but I'll be calling them immediately if this is the case.
Old 10-03-2016, 09:39 AM   #10
57taskforce
All about them K’s
57taskforce's Avatar
Any chance the valves are adjusted wrong?
Tyler
57taskforce is offline   Reply With Quote
Old 10-03-2016, 09:41 AM   #11
LongBox
If you disconnect the coil wire, then crank the engine, does it sound normal? If it does, I'd then do a compression test to see if the piston and valve action is correct.
If all that pans out, you might want to try starting it with the rocker covers off, to see if oil is getting up to the top, and isolate any sounds.
If you are the really careful type, you'll disassemble the engine, and check everything, including the stuff mentioned above. This is the slow, but possibly cheapest way to go.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-03-2016, 09:43 AM   #12
Lefkada
I turned the motor over a few times while working on electrical before priming the oil system and firing the motor up for more than a few seconds. Is it possible I damaged something doing this?
Old 10-03-2016, 09:44 AM   #13
Lefkada
I actually never removed the flywheel but I'll check today to see if it's loose.
Old 10-03-2016, 09:55 AM   #14
geezer#99
geezer#99's Avatar
Sure!!
Whatever amount of turn you last put on the rocker nuts, just back them off half that amount. If you did one turn, back them off 1/2 turn.
That way the lifters are still quiet.
Or it might be just as easy to re run them.
Old 10-03-2016, 10:35 AM   #15
67ChevyRedneck
I wouldn't think it would since the bottom end wasn't rebuilt, but you could have had a dry start with the lifters since it sat so long?
Have you drained any of the oil to look for "glitter" (metal shavings).
With everything you've described, I'm wondering if you have a bent rod or valve.
Jesse James
Project "On a Dime"
Old 10-03-2016, 10:42 AM   #16
Lefkada
I drained the oil last night and didn't see any metallic flake. I'll look again in the light today.
When I tore down the engine, I found a single bent push rod and replaced it. I wonder if I should have just replaced all the push rods.
Old 10-03-2016, 10:43 AM   #17
Lefkada
Sure!!
I will give this a try today!
Old 10-03-2016, 10:43 AM   #18
Marshy
I second this advice. I would pull all the spark plugs and inspect them then crank it over and listen for noise. I suspect you will hear it. If you don't, I would do a comp check, put the plugs back in and start/run it with the valve covers off but damn, something is getting the snot hammered out of it.
What did you all have done to the heads? If he cut the valve seats did he shorten the stems too? Did he deck the heads, how much? What is your quench distance? What pistons are you running, flat/dished/dome?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 10-03-2016, 10:47 AM   #19
Lefkada
Originally Posted by Marshy View Post
I second this advice. I would pull all the spark plugs and crank it over and listen for noise. I suspect you will hear it. If you don't, I would do a comp check, put the plugs back in and start/run it with the valve covers off.
I will try cranking it over without the spark plugs today. I ran the motor last night with the valve covers off but didn't see anything obvious (the knocking was still there).
I had the original heads magnafluxed and they were found to have hairline cracks, so the machine shop give me a different set of heads and performed the valve job on those.
Old 10-03-2016, 10:50 AM   #20
Marshy
Do you know the casting numbers of your old heads and of the new heads? What pistons are you using, flat/dished/dome? Do you know how much deck clearance you had..? Are you running an aggressive cam?
Vortec Engine Build
Old 10-03-2016, 10:58 AM   #21
Lefkada
I do have the old heads' casting numbers. I will check these against the "new" heads casting numbers.
Using flat top pistons.
I do not know how much deck clearance I had or what the cam is.
Old 10-03-2016, 11:04 AM   #22
Marshy
Ok, compare the numbers and let us know.
What head gasket did you use (thickness)?
The frequency of the noise seems relatively high. My fear would be pistons contacting something but I wouldnt expect it to run long like that if it was.
Vortec Engine Build
Old 10-03-2016, 11:29 AM   #23
Lefkada
I'm having trouble figuring out the head gasket thickness. I used the heads gaskets from this Fel-Pro KS2600 kit: https://www.summitracing.com/parts/fel-ks2600/overview/
Edit: according to the description, the kit comes with these head gaskets: https://www.summitracing.com/parts/fel-7733pt2 (4.125 in. Bore, .039 in. Compressed Thickness)
Old 10-03-2016, 11:43 AM   #24
bigmac73
bigmac73's Avatar
.039 thickness as stated
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-03-2016, 11:47 AM   #25
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Always start with the easy low cost stuff before tearing everything all apart;
In order -
1) Rent a bore-scope. Pull the spark plugs and look inside all of the cylinders for loose parts and scarred pistons from valves touching. Also check the oil pan if it's emptied of oil for loose parts.
2) Confirm all of the valve retainers are in place. Confirm the pushrods are equal length and in place.
3) Use a long screwdriver and electric drill to prime the oil system from the distributor shaft hole.
4) Re-adjust the rockers - adjust all to zero lash plus 1/3 turn, turn the motor 45 degrees and re adjust. Do this 6-8 times turning the motor 45 degrees each time you adjust.
5) Confirm firing order / plug wires.
6) Check all ancillary equipment (alternator, A/C, power steering, flywheel, clutch or torq convertor, etc) for proper installation or loose parts.
7) Check oil level. Try starting 'er again.
suprachrgd82 is offline   Reply With Quote
