Old 10-03-2016, 03:24 PM   #1
Tony S.
Gears
Have a 64 with a 454/400th and a stock rearend and I'm looking to upgrade for a tighter twist and better RPMs at 70. Any recommendations as to what a poor boy can do? Thanks all!
Tony S. is offline   Reply With Quote
Old 10-03-2016, 03:40 PM   #2
vince1
Re: Gears
You probably have a 3.73 ratio. A 3.07 will work a lot better. I've got one from I believe an early 71 which is about 1 1/2 wider. After that they go to 5 stud. With 65 and up the panhard bar is shorter and mounts differently.
vince1 is offline   Reply With Quote
Old 10-03-2016, 03:48 PM   #3
vince1
Re: Gears
Yours will probably have 17 spline axles and pressed on backing plates. In 65 I think they went to 30 spline, different drums and backing plates. Preferably get the 65 and up if you are getting a complete differential.
Old 10-03-2016, 04:39 PM   #4
bpmcgee
bpmcgee's Avatar
Re: Gears
Why not just put in a new ring and pinion? Seems a lot easier than changing an axle no?
B
bpmcgee is offline   Reply With Quote
Old 10-04-2016, 05:13 PM   #5
dracko
dracko's Avatar
Re: Gears
3.42 is an option too. Like mentioned, you can just swap the ring and pinion.
dracko is offline   Reply With Quote
Old 10-04-2016, 10:12 PM   #6
Captainfab
60-66 Nut
Re: Gears
I agree that the gears can be changed. But unless the OP has the skills himself to perform the gear change and setup, paying someone to do it will more than likely exceed his 'poor boy' budget.
A '65-'70 12 bolt from a C10, will be a direct bolt in except for the panhard bar.
Depending on tire size a 3.07 or 3.42 gear will work. Changing tire size can help as well to reduce rpm's.
Old 10-05-2016, 12:02 AM   #7
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Gears
I have a 496 big block my truck had 3.72 and i swapped in a set of 3.42...much better.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-05-2016, 12:15 AM   #8
dracko
dracko's Avatar
Re: Gears
Ya that's true, I sold a complete 3.08 rear end for $100 last year so if you can find one that's prob cheaper. Not real easy to find though...and the 3.42 seem even more scarce around here.
Old 10-05-2016, 10:38 AM   #9
LVPhotos
LVPhotos's Avatar
Re: Gears
Need address your purpose of truck. If a daily driver over 55, then gear swap maybe. Is it lowered? Because a 1 to 2 inch of tire will do same as gears. A 3:73 to 3:42 sees little rpm benifit. My 308 gears and 27 in tire ran 3000rpm at 75. If a 29 in tire a 500 rpm drop. These trucks were not built for today's speed. So like me check brakes and steering for worn out parts. It's not all about speed but a 50 year old truck needs help to be safe. I would look for t700 or t200 od trans before gears and a good front end rebuild before hand.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-05-2016, 11:20 AM   #10
vince1
Re: Gears
A 700R4 is on my wish list too. Unfortunately for me someone went through the junkyard and stripped all the transmissions of their kick down cable assemblies and speedo cable drives.
With a 700R4 I could go back to 3.73 gears by putting the parts from a good 64 diff into the original 66 housing with the trashed gears.
