door window q
I have not seen my truck in a while.. my brother has it but the driver side window fell from it track and broke. I want to know if there is a steel channel on the bottom of the window to hold it above the regulator. I do not have any books that show it. Just wondering what to do about it. He said he can get a new window from a local glass shop but I need to find out if there is a channel. Thanks in advance. ps my address will soon be changing to Flagstaff AZ.
Displaced Canadian in Monterey California 1970 K10, 350 HEI, 4spd. 3.73's NP205 33"BFG Mud Terrains Edelbrock Intake and carb. 12 bolt rear,dana 44 front with disk brakes |
Resident Curmudgeon
![]() Join Date: Dec 1999
If I understand your question correctly, then yes, there is a steel channel that the glass fits into. The regulator's nylon rollers fit into this channel. A glass shop should be able to reuse the channel on a new piece of glass for you.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
The part my brother found was mostly gone due to rust. Any suggestions on finding a replacement? Do they make them new or should I seek a used one in good shape or could I have one make fairly eays (I never seen it )
Resident Curmudgeon
I've never seen that part sold by any vendor. It would be easy to find another piece of glass from a board member. There are lots of Canadian members if you want to avoid customs hassles.
