10-03-2016, 06:51 PM | #1 |
Glove box install for a '66 Chevy truck
Any help with a glove box install on my truck would be most helpful.....Cheers.....Robin.
10-03-2016, 08:37 PM | #2 |
Re: Glove box install for a '66 Chevy truck
Will you pay for airfare and lodging?
What's the hang up with your install? |
10-03-2016, 08:55 PM | #3 |
When I installed mine I put the top screws in first. Then pulled it into the slot on the bottom. Getting the top screws in was the hardest part for me.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
10-03-2016, 09:51 PM | #4 |
Does the sides of the glove box liner go behind the bracket that the door swings off
10-03-2016, 10:32 PM | #5 |
Yes.
https://www.flickr.com/gp/27291602@N03/jJ9nda 20161003_212831 by bjohnson388, on Flickr 20161003_212838 by bjohnson388, on Flickr IMG_20160809_205030 by bjohnson388, on Flickr 20160809_195858 by bjohnson388, on Flickr
10-03-2016, 11:56 PM | #6 |
The replacement does not fit perfectly, you will have some gaps so it's normal..
10-04-2016, 08:45 AM | #7 |
from my experience the brand you got will fit great /i got a repops if fact 3 of them -all of them was frayed on the edges and would not fit -last one i bought came from "classis " in kc missouri and fit like a glove -even with my factory air !!!! im thinking the ones of "repops" was on sale from the vendors and probably was returns or severly "shelf worn" but price was cheaper ??so if you buy any always get a good look before buying !
10-05-2016, 04:44 PM | #8 |
I have now completed the glove box install and I am quite happy with the end result, some of the areas around the fitment of the liner could have been better but as my son would say 'It is what it is'. Thanks to all who replied to my thread especially Bret (bj383ss) for the photos, they were a big help. I think we can put this to bed now,
Cheers to all..............Robin Smith |
10-05-2016, 04:56 PM | #9 |
Moderator
How many bumpers did you install? Look under these two areas and you will find a hole for a bumper there on each side. The door hits the bumpers when it opens all the way.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-05-2016 at 05:03 PM. |
10-05-2016, 05:45 PM | #10 |
Bumpers all Done, Thanks Rockenrod....Cheers.
10-06-2016, 01:38 PM | #11 | ||
BRet
10-06-2016, 08:45 PM | #12 |
I resin coated mine before I installed it...fiberglass resin for strength and water proofing.
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
10-08-2016, 02:40 PM | #13 |
Thanks once again to all who contributed to this thread, good idea 'Thunder 71' like a lot of good ideas yours came a bit to late but may help others, Bret (bj 383ss) if I posted a photo you would not be able to tell the difference between yours and mine, time to say 'night night'
Cheers to all.....................Robin Smith. |
01-18-2020, 05:52 PM | #14 | |
Moderator
Looks like it's installed behind the dash metal on the first pic and behind the hinge bracket on the second pic. Am I seeing that? or no?
01-19-2020, 12:25 PM | #15 |
great idea!
Denver/Big Island -- Instagram: Slammed66c10 '46 Fleetmaster Coupe '64 C10 on Ridetech Air Ride '66 C10 on GSI Bagged Chassis - in progress '12 FLHR '11 Custom Homebuilt Chop/Softail |
01-23-2020, 06:38 PM | #16 |
hey guys while all of you are posting pics and i do much much better with seeing things than reading LOL brain issues :P anyway my glove box door is not bent or damaged in anyway but yet the door and the bottom rubs the bottom of the dash and binds up badly! what am i doing wrong here? and also can you guys show me how to install said door maybe im doing that wrong? thanks guys!
01-23-2020, 08:21 PM | #17 |
Here's an interesting aside. My truck is a GMC. I wanted to do away with the Deluxe heater in the engine bay and I installed the basic recirculating heater inside on the firewall. When I went to install my new glove box the other day it wouldn't fit. It was hitting the heater. I had to trim about 2" off the back and reshape the cut-off and staple it on. Had to use my air stapler and bend the legs over. The cardboard is too weak to bend or hammer them flat so I had to use the needle nose and twist them over. They must have had two glove box options back in the day for those with the basic heater.
01-23-2020, 10:33 PM | #18 | |
01-24-2020, 10:55 AM | #19 |
Moderator
I still would like a verification of which way is correct in post #14? Or which works the best.
01-24-2020, 10:11 PM | #20 | |
01-24-2020, 10:18 PM | #21 |
RocknRod i put it behind the bracket on mine i think that is how it goes but im having issues with how to properly install the glove box door as mine on the bottom of the door is binding against the bottom of the dash board and nothing is bent so i cant figure that out but as far as the box sleeve i have no probs with it being behind the bracket im sure that is how it was meant to go! now i cant help but feel like im installing the door wrong tho because of how bad its binding
