mcpherson68's bagged ls1 c10
After years of watching you guys build your trucks, I finally get to start mine! My project truck is a 1968 swb c10. I got this truck out of GA and it was pretty straight other than the typical rust areas. It had a 265 cid small block with a trubo 350 and 3.73 gears. I bought it in Sept of 2015 and started in Feb 2016. What was supposed to be a simple engine swap turned into a full blown rebuild. I bought a 350 4 bolt main out of a 72 C10 that was rebuilt about 4 years ago and when I started it up after installing it in my truck, it spun the #7 rod bearing. When that happened, I decided build the truck I have always wanted.
Here's what I am planning on doing to it. Engine: LS1 and 4L60E out of a donor 99' Z28 Camaro Rear End: I need help picking this out. It has 3.73s right now and I might just run with that for a while. Frame: Z the front 2 inches and C-notch the rear Suspension: 4 Way Air ride Wheels: Stock steelies or cragar series 69 painted white Paint: Matte Mint Green with gloss white bumpers wheels and roof Interior: Either a mid 90s silverado 60/40 split bench or K5 Blazer seats with center console I just want a simple and clean daily driver on air ride. I live in FL so AC is required. Here are some pics. The first is of the truck when I got it, then the engine swap with the spun bearing and then it gets into rust repair. I teaching my self how to weld in panels and do paint and body work so if you see I'm doing something wrong, please call me out. |
Re: mcpherson68's bagged ls1 c10
Here are some more pics of the rust repair. I gotta say, I'm pretty happy with the way the windshield lip came out!
And here's the donor car. This was my buddies car until he blew out the rear end. He blew his engine a couple of years ago and put in a fresh LS1. Set him back about $6k for the engine plus install and another $3k for a remanned 4L60E. Both have just over 20k miles on it. I'm going to leave the engine in the car until I'm ready for it so I can start it up every once in a while.
I'm also going to try and use the rack and pinion steering along with some other components. |
![]() Join Date: Jun 2012
Rust repair looks pretty good! And the engine and trans is a good pick for power
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
