Old 10-03-2016, 10:01 PM   #1
Cam-Shaft
stumped with 8.1 Vortec issue
Hello Gents,
Recently purchased a '91 K5 blazer that was repowered with a 8.1. Overall it runs great and I'm quite pleased with the rig however there is an issue that I cannot seem to track down.
Usually when cold, it starts right up no issues and idles normally. When warm it will often start but idle very low, almost not running at all and when you press the accelerator there is no response at all. The Compushift unit shows that the TPS is working and when I took off the air filter, I can see the intake manifold moving properly.
My fix is usually to shut it off and try again, and usually 10-15 times later it will start and idle normally with the accelerator working again. I am trying to figure out what the correlation is between the low rough idle and the lack of throttle control....
I recently replaced the battery/alternator (problem happened before) and yesterday replaced the MAF sensor as it seemed to fit the problem description.
Warm engine - low idle - no throttle response whatsoever....
Thoughts? Thanks in advance.
Cam-Shaft is offline   Reply With Quote
Old 10-03-2016, 11:28 PM   #2
clinebarger
Re: stumped with 8.1 Vortec issue
Stored Codes??
clinebarger is offline   Reply With Quote
Old 10-03-2016, 11:29 PM   #3
Captainfab
60-66 Nut
Do you have a check engine light? What about a OBDII port to plug in a scanner or code reader?
You might get more responses if you ask a moderator to move this to the LSx swap section.
Old 10-03-2016, 11:37 PM   #4
cableguy0
Moving to the ls section.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-04-2016, 03:42 AM   #5
Cam-Shaft
Thanks for the replies, I'm going to try and get it hooked up to a reader this week. Only concern is I am still learning about how the engine swap was done, so I'm hoping there's not a bunch of random codes from parts that are no longer hooked up. I'll get a reading and post it here
Thanks for moving it, I wasn't sure quite where it belonged being the 8.1 isn't technically a LS
Regards, Jon
Old 10-04-2016, 09:09 AM   #6
Marshy
Regards, Jon
I suggest reading the codes and take note of which are in. Then I like to clear the codes and wait for them to come in while you drive it (check when engine light comes back on) and read what's in. If you don't have a check engine light because of the swap, you might want to consider buying a cheap code reader and leave it plugged in while you drive it. Then you will see them as they come in. Some of the nicer ones they sell at the auto parts store will give you voltages for sensors that are useful for troubleshooting.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 10-04-2016, 03:17 PM   #7
akdg87
akdg87's Avatar
can you scan coolant temp through the PCM? Sometimes they go bad and cause weird problems. Pull the plug on the coolant temp sensor(the one to the engine PCM) while running and see if it clears up. Also check fuel pressure...
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 10-04-2016, 07:50 PM   #8
cableguy0
Regards, Jon
I put it here because the guys who are extremely familiar with tuning the late model stuff usually hang out in here. Tuning seems to be your issue and they should be able to help you in here much more thoroughly than you would get elsewhere.
Old 10-05-2016, 01:05 AM   #9
'63GENIII
'63GENIII's Avatar
My limited experience and research with the L29 (somewhat similar to your 8.1) that is going in the '63 has taught me that if the engine is swapped minus some of the factory smog related parts i.e. rear O2 sensor, EGR, EVAP purge valve that these items will need to be programmed out of the ECM / PCM. If not, as the engine goes from (and correct me if I get this wrong) open loop to closed loop after warm up, it will be looking for the missing sensors / devices. If it cannot find them it may go into a "limp" mode since it cannot get feedback from the missing devices. I do know that when I had my ECM reprogrammed, I was asked for all of the modifications and all of the smog related devices that I had removed so that they could be eliminated from the necessary inputs needed for the ECM to make the engine run correctly.
Even with all of the information that I gave to the programmer, I still suspect that there will be a glitch or two that will need to be worked out when I go to fire it.
Do you have the 0411 PCM (2 long connectors) or the Black Box PCM(4 smaller connectors)? There are a few guys out there that can send (rent) you equipment that can log data from the 0411 ECM while you drive. Should make it easier to find out what the PCM is looking for and trying to compensate for if its missing.
My L29 is missing the EVAP purge, EGR, has had bigger injectors and cam programmed in as well as going from a 4L80E program to a NV4500 manual trans. Is it possible that your ECM had never been re flashed?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-05-2016, 01:44 AM   #10
Cam-Shaft
All great things to try, still waiting on some time as work has been busy as we ramp up training. I have no idea on what was done when the engine swap took place. Correct me if I'm wrong, but the fact that it runs excellent when hot and only when shut off and attempted to restart is when the issue presents itself seems like it would rule out most of that... Plus the fact that it eventually starts after enough trys (even while engine is still hot). Looks like tomorrow I'll have a ride off base and be able to pick up a decent scanner that I can leave plugged in over the weekend while I put some miles on it. Again, thanks for all the suggestions. I'll keep all you gents posted.
Best,
Jon
Old 10-05-2016, 10:40 PM   #11
ls1nova71
ls1nova71's Avatar
What's your fuel system set up like? In tank pump or external? A lot of what you describe sounds fuel related to me, like maybe you're pump is getting hot and not working as effectively as it should. This usually only happens on external pumps though. Could also be that the wiring to the pump is not good enough and can cause the same thing. When your fuel pressure gets low, the throttle will sometimes feel as if it isn't working, so I would get a fuel pressure gauge and check your pressure when cold and also when it starts messing up and see what you've got.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-06-2016, 08:58 AM   #12
cg285
we get a lot of limp mode complaints on the 8.1 when the battery voltage drops too low when cranking. it confuses the pcm which in turn sends it to limp mode
cg285 is offline   Reply With Quote
