10-04-2016, 01:00 AM | #1 |
70+ ( Old Skool Club )
Ever see 15 inch P01 Wheel Covers on a Longhorn?
I saw this yesterday and had to share. I looked at this longhorn and saw the P01's and thought that doesn't look right, 15 inch wheel covers on a 16.5 inch rim. But there it was and factory installed. The centers say GMC as well. Anyone ever seen this before? The truck is an Oshawa build Canadian 1972 GMC truck sold into Canada and the spid says " Z62 Custom Deluxe Equipment " and there is no mention of wheel covers on the spid. the serial # is TCE2421......and the model number on the spid is CE26034.... Would those wheel covers been part of the Z62 Package?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-04-2016 at 07:19 AM. |
10-04-2016, 02:25 AM | #2 |
Re: Ever see 15 inch P01 Wheel Covers on a Longhorn?
It looks like the wheel covers are either installed on the trim ring of the 16.5" wheel or has some type of spacer. I can see the actual hub cap is only a 15" and then it has another ring of some sort. These wheel covers were never made for anything but a half ton
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
10-04-2016, 06:36 AM | #3 |
Could it be the truck has 8-lug 15" wheels? I had aftermarket (wagon wheels) 10 x 15s on an 8-lug truck before. Probably OEM-type were also available. Wheel covers fit on most any 15" steel wheel. What size tires on that one? The wheel covers were always listed on the SPID because they were always an option.
10-04-2016, 07:05 AM | #4 |
Tire size is 16.5 You being the GMC man and it sounds like you haven't come across this before.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-04-2016, 10:22 AM | #5 |
Carpe manana
Wheel covers were an upgrade I believe and as such should be called out on the SPID. 1" spacers exist and do seem to be in use on this truck. Look at the rim of the wheel cover - seems wider but that's the spacer.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-04-2016, 04:52 PM | #6 |
Established how?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-04-2016, 05:32 PM | #7 |
Because the man that is in the truck in the pic is the original owners son and was a teenager and was with his Dad when he picked up the truck in 1972 and those wheel covers were on it. Maybe because they are not on the spid they could have been dealer installed. I've never seen anything like this before and it seems like maybe you haven't either. You are the first person to state you find anomalies from plant to plant on these trucks. Have you ever seen this setup before Tim?
10-04-2016, 05:51 PM | #8 |
20' Daredevil (Ret)
That would be my guess. Just my opinion, nothing more and nothing less.
10-04-2016, 06:21 PM | #9 | |
To me the wheelcover also appears to be stacked on a trim ring or some adapter. The edge deformation supports two pieces. Since the truck at the trim level should have had, as standard, hub caps (and not appearing on the SPID) it would seem these were added post factory. Has me wondering if in this case the truck was actually new or a demo, possibly even used. The latter two could be plausable causes for the change.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 10-04-2016 at 06:48 PM. |
10-04-2016, 09:42 PM | #10 | |
10-04-2016, 10:12 PM | #11 |
Here is an example period part from Ford ('72 E300 van and F250-350 trucks) that actually did just that, adapt a 15" wheelcover to a 16.5" wheel.
http://www.fordification.com/hubcaps...t/d2tz-1210-a/ So it is likely something is like this on the truck in question. However the lack of SPID reference (to me) makes it unlikely "factory". Are there any fleet equipment codes on the unseen SPID. If you are serious about the truck do a GM Canada doc package on it.
10-04-2016, 10:26 PM | #12 |
I've seen the spid and know how to read one and there are no fleet codes.
10-04-2016, 11:22 PM | #13 |
wow, that's just wacky! Have never seen anything like it. very interesting.. I would say that, even if purchased new and the guy you know is the original owner that this almost had to be a dealer add on. There's nothing on the SPID to indicate it was from the factory and PO1s were an upgrade option like Pete mentioned. Dealer would have had ready access to GMC PO1s lying around too. Also, the fact that the adapter ring has the opening for the valve stem - which would appear to leave the stem hidden behind a bumped out cap - and that is how these look to me (no valve stem and the division between cap and ring seems pretty clear to me) leads me to believe the factory would not do this (i.e. no exposed valve stem). But who knows. I do think it is very plausible that the dealer did this to make this truck stand out a little before the original owner ever walked through the door. So, to him, the truck came like this "new" - which it did. But "came like that new" doesn't mean it rolled out of the factory that way either. Dealers were a little more inventive back then, that's what I'm thinking - all part of the local marketing wars. That's my bet anyway, who knows!
10-04-2016, 11:25 PM | #14 | |
On Fords is the only place I've ever seen them, and they used them into the 80s. When I was into Fords I used to toss them and replace with dog dish caps. |
10-04-2016, 11:57 PM | #15 |
BlahBlahBlah
If you know the family and are working with the son on buying it, I'm assuming you can see it in person anytime. Would the son care if you popped off a hubcap just to see what's underneath?
10-05-2016, 07:45 AM | #16 |
The adapters would have been my next guess. I have never seen them used, that I've known of, but have heard of them. No truck came from factory with PO1s that weren't an option listed on the SPID and GM didn't offer these. Even the Cheyenne Super/Sierra Grandes came with chrome hubcaps with the wheel covers being an option. Just as there is the Sliver Book provided by GM for aftermarket upfit to their customers, an item not found in there could have been added by the dealer either at the customer's request or just because they think it looks good and will make a truck more attractive. The Silver Book may have offered Reading utility beds while a customer may have preferred another brand not listed. That body could still be arranged by the dealer to be part of original invoice and financed in the same auto loan. This is a dealer upgrade just as saddle tanks were. At least that's how it appears to me with what I know.
10-05-2016, 02:27 PM | #17 | |
Sadly I do not recall an RPO code or part number. They stuck with me because at the time I was interested in creating a similar setup to adapt a 14" wheel cover to a 15" wheel. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-05-2016, 02:57 PM | #18 |
Think this is it Keith?
From my 73-78 parts catalog. Not listed in my illustration catalog though.
10-05-2016, 05:07 PM | #19 | |
10-05-2016, 05:11 PM | #20 |
6>8 Plugless........
I'm betting the dealer had these caps from another new truck and installed them via the buyer's request. Dealers did what they could to please their customer back then from the stories I've heard from older folks that still have their rides from the 60's through early 70's. That sure is a nice truck from the pic you posted though.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-05-2016, 05:53 PM | #21 | |
Most hubcaps, wheelcovers and many mirror options were shipped loose ("loose equipment") as Keith describes. But in the case of factory provided options they would be listed on the build sheet and in most cases the SPID too unless included with another option. Base build items, like hub caps, would be listed on the build sheet but only rarely on the SPID. As example, a Cheyenne without conflicting option or upgrade shipped with painted hub caps. A Cheyenne Super shipped, again in most cases, with chromed hub caps. But neither lists hub caps on the SPID. So if you have, say, wheelcovers or camper mirrors listed on the SPID they were provided by the factory but actually dealer installed.
10-05-2016, 06:54 PM | #22 | |
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-05-2016 at 07:02 PM. |
10-06-2016, 07:23 AM | #23 | |
Having given it further thought - they could have been released for a specific combination of options (rather than it's own separate, stand alone option code). Said differently - if you got a c20 with a certain tire/wheel and PO1 then it would drive the adapter. If that was the case the part number for the adapter (and wheel cover) would show on the build sheet but only the RPO P01 would show on the SPID. K
10-06-2016, 07:48 AM | #24 |
You could always ask the son if you could pop one off and solve this mystery
10-06-2016, 04:18 PM | #25 |
I don't think there is a mystery. This really looks and sounds like these hub caps were dealer installed. I have a 68 GS400 that had a dealer added stage 1 kit. Good luck finding the documents for this. This is just another example of it wasn't factory and good luck finding the documents/info proving the vehicle had it installed at the dealer. If the dealership still exists, you might have a chance. In my case the dealership has been long gone.
