10-08-2003, 04:56 PM | #1 |
its just $$$$$
disc swap on 68 2wd
what is the easiest way to convert to disc and 5 lug on a 68 2wd. Can you swap ball joints and use 73up spindles and brake components? any help would be greatly appreciated.
10-08-2003, 06:15 PM | #2 |
Fabricate till you "puke"
Yep, swap the ball joints(go for the yr of the spindle), & you can bolt the later spindles on. You need to also grab the steer linkage(inneres outers & sleeves on the tie rods, & the center link). note that the 73 up lower b Joints will press into the 68 lower arms, but you will need to grind the steer stops on the spindles to correct the steering radius. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
