10-05-2016, 12:26 AM | #1 |
Lowering 3/4 ton
I'm about to pick up an 88 R20. I feel I've searched all over for lowering kits. I have found Western Chassis makes a spindle but cannot find springs. As far as a flip kit I can only find DJM. I've seen some scary DJM flip kits for the 1/2 tons on this forum so I'm not too confident about that. Which also leaves me with Chassis Tech aka Airbagit. They have kits available but their quality is also questionable. I know I can switch to 1/2 ton suspension but that's further down the road. Any help on springs and flip kit for 3/4 2wd trucks? Thanks
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
10-05-2016, 11:25 AM | #2 |
67-72 parts collector,…
Re: Lowering 3/4 ton
What about using 73-87 1-ton dually lowering components?
(Not the spindles because the brake caliper mount is different) But springs, flip kits, and c-notches. You might PM member Cochino12. I believe he has lowered a few of these.
10-05-2016, 11:46 AM | #3 |
I considered 1 ton flip kit but wasn't sure. I'll PM him, thanks
10-05-2016, 12:59 PM | #4 |
You can buy the axle perches for around $25 bucks. Most rearend shops can weld them on for you for $100 bucks or so. Have them match the angle of the other side and you should be close enough to use a 2 degree shim if needed.
I had a Chassis Tech/Airbaggit shackle/hanger kit on my C20 for a bit. I pulled a few of the bottom leafs and the overload. Got me 6 inches of drop. Before: After: It was on my driveway which slopped a bit. The drop was more noticeable when on flat ground. I ended up bagging it before I got the front down. You could keep everything the same and just special order springs from a spring shop to whatever drop you want as another option. Will likely be more expensive though.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-05-2016, 09:33 PM | #5 |
I bought all my parts for my 86 C20 from Western Chassis. If you haven't called them yet, you need to. They don't have half of there stuff listed on line, so a phone call is best. I have been really pleased with everything so far, from them.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
10-06-2016, 12:35 AM | #6 |
Thanks! Do you have any pictures of yours lowered?
10-06-2016, 12:36 AM | #7 | |
10-06-2016, 10:20 AM | #8 | |
10-06-2016, 01:35 PM | #9 |
As low as I can get static!
Honestly I was hoping for at least 6" all around. Would be nice to get a 6/8 drop if possible.
10-06-2016, 01:56 PM | #10 | |
Anyway, I would do a an axle flip (which will get you about 8'' with the stock spring pack). Run a 3 inch drop spindle and a 2/3'' drop spring. It will get you your 6/8. You will need a C-notch for the rear. If you plan on running shorter tires at some point you may want to rethink your plan though.
10-06-2016, 02:06 PM | #11 |
What's the budget?
10-06-2016, 08:52 PM | #12 |
Here you go, I'm very pleased with the ride. Its better than before, surprises most who take a ride with me. I'm still going to try and level it a bit, by dropping the rear a little lower. Was hoping to do it this weekend, but the weather has other things in store for me.
Ken
10-06-2016, 10:48 PM | #13 | |
10-06-2016, 11:15 PM | #14 |
It followed me home?
This truck was lowered 4/5. The rear was hangers shackles with overload removed, with another leaf or maybe two removed it would have leveled out real nice. All WC stuff
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-06-2016, 11:23 PM | #15 | |
10-06-2016, 11:30 PM | #16 |
Sorry didn't mean to ignore your question. I don't have a specific budget. I'm not wanting to spend thousands. Would be nice if I could get it all for under a grand.
10-06-2016, 11:32 PM | #17 | |
Front is spindles and a coil cut?
10-06-2016, 11:35 PM | #18 |
I received from WC in 3 heavy boxes was. Two spindles with 2 inches of drop, 1 inch lowering front springs. Rear leaf spring shackles and front hangers. I did have to do some modifying on the hangers. They didn't match up to my bolt holes, so rather than drill more holes in my frame. I filled in the holes and drilled new ones in the hangers.
Ken
10-06-2016, 11:51 PM | #19 | |
10-07-2016, 02:30 AM | #20 |
I went back and looked I think I have 2 inch drop front springs. When I installed everything I replaced all the ball joints, sway bar mounts, any bad/worn tie rod ends. 4 new drop shocks from WC. I the rear I'm in the hole in the rear shackle that gives the lowest setting, also the lowest hole in the front hangers.
I did remove the 3rd leaf from the top out of the spring pack. Leaving the overload spring in place. I am running a 2 degree shim on each side of the leaf springs to keep the vibration away. I'm not sure how I achieved the amount of drop I did, but really pleased with my work. I'm running the stock wheels 16 X 7.5 with the stock size tire 215R7516LT. Which surprise me with such a heavy optioned truck. It came with 350,4bbl,700r4, 3:42 rear axle, engine oil cooler, towing package, a heavy optioned interior,carpet,bed lamp, custom door panels with power door locks but no power windows.dual fuel tanks,chrome rear step bumper. Had the slid out spare tire rack.Clock with all the other gauges, the stainless steel dash & door panel trim. A before picture. I will have pictures of my interior soon. I have been working on it for a few weeks now. Its been a big job as well, not so much dirty or beat up. Just getting things to match somewhat close. Ken
