10-05-2016, 02:29 AM | #1 |
Carb ID and adjustment info
What am I looking for to ID which carb I have?
Also, where can I find info on proper adjustments? Its been a long time since Ive payed with a carb'd engine. The reason I ask... Sometimes It feels like its idling high, well into my trip... already warmed up that is. Not quite as high as the high idle... but its seems high. Other times it will start to stumble a little... Ive never let it continue to see if it will actually die, a little tap on the gas gets things going again. Once this happened I was looking in the side mirror when hitting the gas and I had some black smoke when I hit the gas. Occasionally get a strong smell of gas when getting out of the truck, but I have no visible fuel leak. Though even if its all unrelated, itd probably still be a good idea to know what I am doing and to have the carb properly tuned. thanks
1986 C30 3+3 454 w/3spd Last edited by Shibbershabber; 10-05-2016 at 02:45 AM. |
10-05-2016, 08:48 AM | #2 |
Re: Carb ID and adjustment info
Could be any carb.
Take a pic! |
10-05-2016, 12:55 PM | #3 |
If it's a quadrajet check the drivers side of the carb for numbers running vertically.
Do you know if your choke is operating properly? Check to see if the choke flaps are open once it's warmed up and it's coming off the high idle cam on the choke side. I had similar problems and after I replaced a dead choke thermostat I was dialing it in when gas starting leaking out of the side of the carb. For more details search my post 305 dies when warmed up - there was some great advice from the guys on the board
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
10-06-2016, 05:31 AM | #4 |
Also the throttle shafts wear out the bore and create a random vacuum leak. There's a bushing kit to fix that.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
10-24-2016, 02:50 AM | #5 |
Finally had a chance to check it out.
Its a Quadrajet R4-M4MEF #17085004
1986 C30 3+3 454 w/3spd |
10-24-2016, 09:39 AM | #6 |
A pic would still be nice!
With the air cleaner off, both sides and the front. Could be something simple or major. Could be rebuild time! |
10-25-2016, 08:41 PM | #7 |
I have an M4MED with some of the same issues. Part of my trouble was the EGR valve, but I am still idling higher than normal and my next step is to replace the base plate gasket, I'm fairly certain there is a vacuum leak there. Do you have A/C? If so there is a fast idle solenoid, or "throttle kicker" that kicks up the idle speed when the A/C or DEF is engaged. Unplugging that might help a bit. The mixture screws on these carbs are factory set and require knocking out some plugs to adjust. I'd try checking the choke as mentioned above as well as checking for a vacuum leak before you break out the "magic screwdriver". I do have an '86 factory service manual that covers these carbs, however I don't have a scanner but if I can look up something specific for you I'd be glad to help.
10-25-2016, 09:46 PM | #8 |
Found an online version of the FSM on another forum:
http://www.73-87chevytrucks.com/tech...ice_Manual.pdf |
